[postgis-users] Configuration and performance of PostGIS
ruvenml at beamerbrooks.com
Mon May 9 10:41:59 PDT 2022
The Walk the Network algorithm returns all points reachable from a
particular starting point. The result is a tree. It only appears to
be a single line because the network given as an example has been
constructed without branches.
Try adding:
insert into network values ('linestring(3 4, 2 3)', 14);
Note that what is returned is now a tree.
Now, try adding:
insert into network values ('linestring(0 0, 2 3)', 15);
If you are patient enough, it will blow up with a memory allocation
error because it creates a loop in the network.
(Again, my appreciation to Paul Ramsey for constructing such a focused
example.)
Does a tree structure of paths starting at a designated node and ending
at any node which has no outgoing edges satisfy your requirements or do
you want the minimum cost/distance path? If so, you have lots of
algorithms to choose from and watching some videos on graph theory might
be time well spent.
Ruven Brooks
On 5/9/2022 7:39 AM, Shaozhong SHI wrote:
> Hi, Imre,
> What happens if more than 1 result from the Walk the Network?
> Can recursive query return all possible results?
> How to handle such results?
> My guess that memory allocation error occurred because that more than
> 1 result is found and the recursive query does not know what to do.
> What is your thought?
> Regards,
> David
> On Fri, 22 Apr 2022 at 22:14, Imre Samu <pella.samu at gmail.com> wrote:
> > as St_intersects or recursive query used,
> The other alternative ( ~ less efficient ) is using a “noded”
> network table ( "edge_table" )
> in the recursive query. ( and don't forget to add indexes to the
> "source" and "target" columns )
> WITH RECURSIVE walk_network(id, source, target, targetPoint) AS
> (SELECT et.id
> <http://et.id>,et.source,et.target,ST_EndPoint(the_geom) as
> targetPoint
> FROM edge_table et WHERE et.id <http://et.id> = *12*
> UNION ALL
> SELECT e.id <http://e.id>, e.source, e.target
> ,ST_EndPoint(the_geom) as targetPoint
> FROM edge_table e
> , walk_network w
> WHERE w.target = e.source
> SELECT ST_AsText(ST_MakeLine(targetPoint))
> FROM walk_network
> | st_astext |
> | LINESTRING(4 2,3 2,2 1,1 1,0 0) |
> (1 row)
> regards,
> Imre
> Imre Samu <pella.samu at gmail.com> ezt írta (időpont: 2022. ápr.
> 22., P, 16:39):
> > With a large data set,
> please give more detail:
> - How large?
> - and what is your real "business problem"? what type of
> network?
> > I tried to use this
> http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html in
> the PostGIS.
> As I see this is a directed "network graph", and I will try
> using the pgRouting tool - for a large graph!
> /( "pgRouting extends the PostGIS/PostgreSQL geospatial
> database to provide geospatial routing *and other network
> analysis functionality.*" )/
> The pgRouting project did not exist in 2010/07 when this
> blogpost was written!
> so I have adapted the example network ( from the original
> blogpost )
> to pgRouting and this is my sample result
> ---------- ALL "downstream path" from "all deadends" sorted by
> descending cost ---------
> | route_cost | start_vid | end_vid | the_geom_text
> | edge_ids |
> | 6.24 | 3044 | 3000 | LINESTRING(4 4,3 4,2 3,1
> 2,1 1,0 0) | {13,9,6,3,1} |
> | 5.83 | 3043 | 3000 | *LINESTRING(4 3,4 2,3 2,2
> 1,1 1,0 0) | {12,8,5,2,1} |*
> | 4.83 | 3024 | 3000 | LINESTRING(2 4,2 3,1 2,1
> 1,0 0) | {10,6,3,1} |
> | 4.41 | 3014 | 3000 | LINESTRING(1 4,1 3,1 2,1
> 1,0 0) | {11,7,3,1} |
> | 3.41 | 3031 | 3000 | LINESTRING(3 1,2 1,1 1,0
> 0) | {4,2,1} |
> and the second line is same as in the blogpost (
> /"Downstream(12)" /example) ,
> just with an extra "deadends" points ; the edges
> :* {12,8,5,2,1} *
> start_vid : starting node/vertex id ( "deadends" in this example )
> end_vid : ending node/vertex id constant 3000 (0,0)
> node/vertex id = 3000 + X*10+Y coordinate // ( 2,1 ) -->
> 3021 ; (0,0) --> 3000
> > Whenever geospatial functions such as St_intersects or
> IMHO: A good scalable data model is extremely important.
> pgRouting has 2 important (separated) steps.
> - creating a routing topology - route optimized database (
> with "start" - and "end" node/vertex )
> - fast routing/graph/"network-walking" functions - without
> the geometry ( using Boost Graph c++ library )
> ( in this example I have used
> https://docs.pgrouting.org/3.3/en/pgr_dijkstra.html )
> and this is my adapted "routing" topology edge table :
> DROP TABLE IF EXISTS edge_table CASCADE;
> CREATE TABLE edge_table (
> id bigint primary key,
> source bigint,
> target bigint,
> cost float,
> reverse_cost float,
> the_geom geometry
> -- network example from
> INSERT INTO edge_table VALUES( 1, 3011, 3000, 1, -1,
> 'LINESTRING(1 1, 0 0)');
> INSERT INTO edge_table VALUES( 2, 3021, 3011, 1, -1,
> 'LINESTRING(2 1, 1 1)');
> INSERT INTO edge_table VALUES( 3, 3012, 3011, 1, -1,
> 'LINESTRING(1 2, 1 1)');
> INSERT INTO edge_table VALUES( 4, 3031, 3021, 1, -1,
> 'LINESTRING(3 1, 2 1)');
> INSERT INTO edge_table VALUES( 5, 3032, 3021, 1, -1,
> 'LINESTRING(3 2, 2 1)');
> INSERT INTO edge_table VALUES( 6, 3023, 3012, 1, -1,
> 'LINESTRING(2 3, 1 2)');
> INSERT INTO edge_table VALUES( 7, 3013, 3012, 1, -1,
> 'LINESTRING(1 3, 1 2)');
> INSERT INTO edge_table VALUES( 8, 3042, 3032, 1, -1,
> 'LINESTRING(4 2, 3 2)');
> INSERT INTO edge_table VALUES( 9, 3034, 3023, 1, -1,
> 'LINESTRING(3 4, 2 3)');
> INSERT INTO edge_table VALUES(10, 3024, 3023, 1, -1,
> 'LINESTRING(2 4, 2 3)');
> INSERT INTO edge_table VALUES(11, 3014, 3013, 1, -1,
> 'LINESTRING(1 4, 1 3)');
> INSERT INTO edge_table VALUES(12, 3043, 3042, 1, -1,
> 'LINESTRING(4 3, 4 2)');
> INSERT INTO edge_table VALUES(13, 3044, 3034, 1, -1,
> 'LINESTRING(4 4, 3 4)');
> full example code - with data&code:
> https://gist.github.com/ImreSamu/efda6093b67391a0edafff39d8056cb5
> if you are interested in more examples.. check the pgRouting
> tutorial
> for example: *"Pre-processing waterways data"*
> https://workshop.pgrouting.org/2.7/en/un_sdg/sdg11-cities.html#pre-processing-waterways-data
> regards,
> Imre
> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont:
> 2022. ápr. 22., P, 1:22):
> recursive query used, the PostGIS appears to spawn away to
> many child queries and just obliterate the CPU. Nothing
> finishes.
> That forced me to try out to do the some tasks on the FME
> server.
> I tried to use this
> <http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html> in
> the PostGIS.
> I tried to linecombiner in FME. LineCombiner | FME
> (safe.com) <https://www.safe.com/transformers/line-combiner/>.
> With a large data set, the running of processors were
> monitored. It was estimated the PostGIS one would take 16
> days to complete.
> But, it only took a few minute to do the same thing in FME.
> This suggests that something is not right with the PostGIS
> Server.
> Have anyone got experience with configuration and
> improving perfomance of PostGIS Server?
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220509/4a62d5d4/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220509/4a62d5d4/attachment.png>
