[postgis-users] Recursive query - ERROR: invalid memory alloc request size 1073741824
Imre Samu
pella.samu at gmail.com
Mon May 9 12:01:37 PDT 2022
> encountered more than 2 answers/outputs.
> It may get confused and cannot finish.
You can find a very good SQL "graph" tutorial/basics - with examples.
https://docs.yugabyte.com/preview/api/ysql/the-sql-language/with-clause/traversing-general-graphs/
So you have to decide - what type of graph you have
- Undirected cyclic graph
- Directed cyclic graph
- Directed acyclic graph
- Rooted tree ( a specialization of the directed acyclic graph. )
If you know the "type of your graph network" ( and the name of your
problem ) Then it will be easier to find an algorithm.
You can ask your DB team - or You can search the internet.
But without minimal example data - not so easy to help you.
IMHO: Your link ["Network Walking in PostGIS"(2010)] is a very simple
"Rooted tree" example.
Regards,
Imre
Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 8., V,
22:10):
> Hi, Imre,
> There is a possibility that the Walk the Network (Network Walking in
> PostGIS · Paul Ramsey (cleverelephant.ca)
> <http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html?m=1&msclkid=5cf8409ecf0a11ecbbe2896397a25c2b>)
> Can we build something in the script to report these and should there be
> an exception, allow it to complete the task?
> Regards,
> David
> On Sun, 8 May 2022 at 00:59, Imre Samu <pella.samu at gmail.com> wrote:
>> Hi David,
>> > There is a loop of recursive query. It runs at a point where it stops.
>> >Can anyone provide pointers how to solve this problem or work around?
>> Please share "this" recursive query;
>> My guess: Probably you have a "forever/endless loop" in your data; *so
>> you have to LIMIT the recursive part ;*
>> related links :
>> 1.) with limiting "depth" ( where depth < 1000 )
>> "Prevent infinite loop in recursive query in Postgresql"
>> https://stackoverflow.com/questions/51025607/prevent-infinite-loop-in-recursive-query-in-postgresql
>> 2.) with LIMITING clause
>> https://www.cybertec-postgresql.com/en/recursive-queries-postgresql/
>> *"This example also demonstrates how an endless loop can be avoided with
>> a LIMIT clause on the parent query."*
>> Regards,
>> Imre
>> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 7.,
>> Szo, 15:23):
>>> This error turned up.- ERROR: invalid memory alloc request size
>>> 1073741824
>>> Regards,
>>> David
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220509/56c1ffc6/attachment.htm>
