[postgis-users] DE-9IM pattern string for end of a line meeting start of another line
Alexandre Neto
senhor.neto at gmail.com
Tue May 10 01:30:04 PDT 2022
I would work with ST_startpoint and ST_endpoint
A segunda, 9/05/2022, 20:05, Martin Davis <mtnclimb at gmail.com> escreveu:
> The DE-9IM model isn't able to express line direction.
> On Mon, May 9, 2022 at 11:42 AM Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
>> The DE-9IM pattern string for two lines meeting at both end is found to
>> be FF1F0F1F2.
>> Is it possible for DE-9IM to have a pattern string for end of a line
>> meeting start of another line? Namely, they share a node.
>> Regards,
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220510/a93f9614/attachment.htm>
