[postgis-users] Non GIS uses of PostGIS: Any tips?
Rory Meyer
rory.meyer at VLIZ.be
Sun May 22 23:17:28 PDT 2022
Afternoon everyone,
I'm assisting a PhD student with their work and I think PostGIS could provide some interesting tools. The problem is that it's using spatial data in a non GIS way.
The student is monitoring the settling behaviour of oyster sprats (larvae) to determine the natural features that lead up to oyster reefs. The experiment is to have a bunch of sprats in a petri dish, simulate a predator or existing oyster reef using chemicals, and to measure the settlement behaviour over several hours using a webcam mounted above the petri-dish. The initial steps would be to use computer vision tools to get an (x,y,t) vector for each oyster sprat, or movement segment, for the duration of the experiment. Using PostGIS functions to build trajectories, calculate average/min/max speed per segment, see if there are any intersections between multiple sprats, possibly map trajectories to behaviours. I'm not sure what else, I'm not a biologist.
My question is how do you do this with a non-spatial SRID? Can I just use pixel locations as X,Y fields, set the SRID to 0 and get pixels/sec out of any ST_funcs? Is there some previous work done on creating a camera specific SRID (probably a bit overkill) to take into account distortions and transform pixel/sec to meter/sec?
Regards,
Rory
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220523/a081c046/attachment.htm>
