[postgis-users] PostGIS 3.3.0alpha1 released
Anthony DeBarros
anthonymdebarros at gmail.com
Mon May 30 11:51:47 PDT 2022
On Mon, May 30, 2022 at 12:45 PM Regina Obe <lr at pcorp.us> wrote:
> Hi Anthony,
> Love your book by the way:
> https://nostarch.com/practical-sql-2nd-edition
Thanks, Regina! And thanks for the info.
> Unfortunately I don’t think EDB makes installers (or makes available
> binaries) until it reaches RC1 or final.
> Figuring that no one can use the postgis extension until they do, I don’t
> bother shipping postgis extensions for PostgreSQL beta releases either.
> However you should be able to find PostGIS 3.3.0 alpha1 for windows for
> PostgreSQL 11 – 14. The only feature in PG15 you will lack is the improved
> index speed. Everything else in lower versions will be the same.
> The PG14 windows binaries are here -
> https://winnie.postgis.net/download/windows/pg14/buildbot/
> You will see a 3.3.0alpha1 -
> https://winnie.postgis.net/download/windows/pg14/buildbot/postgis-pg14-binaries-3.3.0alpha1w64gcc81.zip
> and a 3.3.0dev..
> https://winnie.postgis.net/download/windows/pg14/buildbot/postgis-pg14-binaries-3.3.0devw64gcc81.zip
> The dev is always the most recent as it gets built after each commit to
> the postgis code base.
> The structure of the zips is patterned after the windows PostgreSQL EDB
> setup, so you should be able to just overwrite your files.
> A couple of caveats,
> 1) The GEOS packaged with this is latest GEOS development and since this
> is shared across PostGIS versions, it would force your 3.1 or lower to be
> using the development GEOS. Which is both good and bad depending on how
> you look at it.
> 2) The PostGIS 3.3.0 is compiled against latest GEOS 3.11, so if you don’t
> use the one in the zip (and use your existing), the extension won’t load.
> 3) The PostGIS 3.3.0 alpha and dev, I compiled with –minor-version, which
> means the libs are called postgis-3.3.dll etc, this is so you could run a
> stable postgis in one database and dev in another database.
> Let me know if you run into any issues.
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Anthony DeBarros
> *Sent:* Monday, May 30, 2022 10:35 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] PostGIS 3.3.0alpha1 released
> On Sat, May 21, 2022 at 9:34 PM Regina Obe <lr at pcorp.us> wrote:
> The PostGIS Team is pleased to release PostGIS 3.3.0alpha1!
> This is the first release to support PostgreSQL 15.
> Hi, Regina,
> Is there a Windows installer for this available?
> Many thanks,
> Anthony DeBarros
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220530/7747f2f4/attachment.htm>
