[postgis-users] Append a list of tables to an empty table to form a whole table
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Fri Oct 14 01:48:55 PDT 2022
David, this is a list for Post*GIS *related questions. Your question is
strictly Post*Gres* related.
However, you can use the following SQL commands:
-- Create new empty table with the same columns/types as "table_a".
CREATE TABLE new_table (LIKE table_a);
-- Create primary key constraint and index on geometry
ALTER TABLE new_table ADD PRIMARY KEY (your_pk_column); -- change to
relevant column name
CREATE INDEX ON new_table USING GIST (your_geom_column); -- change to
-- Insert rows from 3 tables with the same structure into table "new_table"
INSERT INTO new_table SELECT * FROM table_a;
-- Will only work if there is no overlap on primary key values in the 3
tables
INSERT INTO new_table SELECT * FROM table_b;
INSERT INTO new_table SELECT * FROM table_c;
Best regards
Bo Victor Thomsen, Ms.Sc.Eng
aestasGIS Denmark
Den 14-10-2022 kl. 07:59 skrev Shaozhong SHI:
> How best to append a list of tables to an empty table to form a whole
> table?
> Pseudo codes show the desirable logic.
> There are a list of tables with exactly same colums
> table_a
> table_b
> table_c
> Create an empty table emp_table
> Foreach a_name in ARRAY ARRAY['table_a', 'table_b', 'table_c'] loop
> insert into em_table as select * from table a_name
> end loop;
> Can something like that be done is PostGIS?
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20221014/3dc7144c/attachment.htm>
