[postgis-users] ERROR: type "raster" is only a shell
Marcelo Marques
marcelosmbr at gmail.com
Wed Sep 7 14:06:55 PDT 2022
-- Platform:
Windows Server 2019
PostgreSQL 12.12
Postgis 3.2.3
*SELECT postgis_full_version();*
"POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""120""
GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
(Internal)""
(raster procs from ""2.4.4 r16526"" need upgrade)"
** NOTE: postgis 3.2.3 and raster 2.4.4 **
***-- Upgrade the Postgis Extensions***
*SELECT postgis_extensions_upgrade();*
NOTICE: Packaging extension postgis_raster
*ERROR: type "raster" is only a shell*
CONTEXT: SQL statement
*"CREATE EXTENSION postgis_raster SCHEMA public VERSION unpackaged;ALTER
EXTENSION postgis_raster UPDATE TO "3.2.3""*
PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
SQL state: 42704
***QUESTIONS:***
Why the extension upgrade returns "ERROR: type "raster" is only a shell"
Is this another bug ???
Is there any other workaround for this issue besides
"uninstall_rtpostgis.sql" described below ???
***--SOLUTION: ***
-- uninstall postgis_raster
psql
\c rev
\i 'C:\\Program Files\\PostgreSQL\\12\\share\\contrib\\postgis-3.2\\
*uninstall_rtpostgis.sql*'
"Upgrade completed, run SELECT postgis_full_version(); for details"
NOTICE: Extension postgis_raster is not available or not packagable for
some reason
NOTICE: Extension postgis_sfcgal is not available or not packagable for
some reason
NOTICE: Extension postgis_topology is not available or not packagable for
some reason
NOTICE: Extension postgis_tiger_geocoder is not available or not
packagable for some reason
Successfully run. Total query runtime: 144 msec.
1 rows affected.
(Internal)"""
*CREATE EXTENSION postgis_raster;*
CREATE EXTENSION
Query returned successfully in 227 msec.
GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
(Internal)"" RASTER"
*SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis%';*
"name" "default_version" "installed_version" "comment"
"postgis" "3.2.3" "3.2.3" "PostGIS geometry and geography spatial types and
functions"
"postgis_raster" "3.2.3" "3.2.3" "PostGIS raster types and functions"
*DROP EXTENSION postgis_raster;*
DROP EXTENSION
Query returned successfully in 94 msec.
I appreciate the assistance to clarify my questions.
Thanks,
Marcelo Marques | Principal Product Engineer | Esri - www.esri.com |
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220907/04ba2259/attachment.htm>
