[postgis-users] pg point cloud backup problem
Regina Obe lr at pcorp.us
Thu Sep 22 10:35:28 PDT 2022
As discussed on IRC
ALTER EXTENSION pointcloud_postgis UPDATE;
Doesn't work.  For now one can do
DROP EXTENSION pointcloud_postgis;
CREATE EXTENSION pointcloud_postgis;
This is safe, since if you have any functions, views, or data reliant on
this extension, then the DROP EXTENSION call will fail.
The issue with UPDATE not working  is detailed in --
https://github.com/pgpointcloud/pointcloud/issues/307
And I've submitted a pull request to solve this -
https://github.com/pgpointcloud/pointcloud/pull/327
I'm going to wait a little longer before packaging to see if there is a new
version that
1) supports PG15, since that fix is already in master
2) The pointcloud_postgis upgrade issue
Thanks,
Regina
> -----Original Message-----
> From: Regina Obe [mailto:lr at pcorp.us]
> Sent: Tuesday, September 20, 2022 11:34 PM
> To: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> Subject: RE: [postgis-users] pg point cloud backup problem
> One more update.  To patch your systems, make sure to copy the files in
the
> respective package into same named folders of your postgresql install.
> This will usually be in C:\Program Files\PostgreSQL\<pg version here>\
> Once you've copied the files, make sure to do
> ALTER EXTENSION pointcloud UPDATE;
> In each database you have it installed.
> > Sent: Tuesday, September 20, 2022 11:31 PM
> > I wrote this on IRC too, but will repeat for completeness.
> > I have the extensions for pgpointcloud built for PostgreSQL 11 - 14.
> > You will find them in the respective extras folders here
> > https://winnie.postgis.net/download/windows/
> > So for example, the package for PG14 is -
> https://winnie.postgis.net/download/windows/pg14/buildbot/extras/point
> > c
> > loud-pg14-binaries-1.2.3w64gcc81.zip
> > PG15 I don't have yet because the fix for PG15 hasn't been tagged yet,
> > though it is fixed in master branch.
> > > Sent: Tuesday, September 20, 2022 1:41 PM
> > > I'll have 1.2.3 in next release.  I'll try to push that out this
coming
> weekend.
> > > Thanks,
> > > Regina
> > > > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> > > > On Behalf Of ????? ????????
> > > > Sent: Tuesday, September 20, 2022 1:02 PM
> > > > To: postgis-users at lists.osgeo.org
> > > > Subject: [postgis-users] pg point cloud backup problem
> > > > There is an "old" problem with pg point cloud db dump/restore
> > > > https://github.com/pgpointcloud/pointcloud/issues/197
> > > > It looks like it was fixed but it is not included in postgis
> > > > windows distribution yet What version of pg pc will be included in
> > > > next postgis and
> > > when?
> > > > SELECT pc_version(), PostGIS_Version()
> > > > >"1.2.1" "3.2 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> > > > Pavel
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > https://lists.osgeo.org/mailman/listinfo/postgis-users
