[postgis-users] No extension
Simon SPDBA Greener
simon at spdba.com.au
Thu Sep 29 15:53:56 PDT 2022
Regina,
> This I suppose could be a permission issue or search path one.
I used pgAdmin 4 to set the search_path parameter to "$user", public,
topology for all the databases.
Didn't seem to make a difference.
> Are you using the same account in QGIS to connect as you are in pgAdmin?
Yes, I believe so. All connections use the postgres user who owns all
the databases.
Are you connecting from QGIS PostGIS layers or via QGIS DBManager menu
option?
Both.
> If you haven’t tried DBManager, I would try that to see what tables
> you are able to see. That should give you a clue if it’s a permission
> issue.
When I connection using DBManager to one of the databases (dfdb) in the
instance I still get the following message....
2022-09-30T08:35:24 WARNING Database connection was successful, but
the accessible tables could not be determined.
If I try to connect to another database in the same instance (gisdb) I get
FATAL: database "gisdb" does not exist.
Sorry if this is not that helpful.
regards
Simon
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Simon SPDBA Greener
> *Sent:* Thursday, September 29, 2022 2:03 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] No extension
> Regina,
> Thanks for the reply.
> > What does
> > SELECT * FROM geometry_columns;
> > Return. I’m guessing maybe QGIS is complaining about lack of
> spatial tables.
> It returns a data grid showing all the spatial layers.
> > Looked like your PostgreSQL 13 is running on 5432, you could just
> disable it. I assume it’s maybe still running in services?
> The strange thing was that it had been uninstalled. I removed the
> rogue connection in PgAdmin 4 and it fixed the problem.
> In my new instance I created a database for each of the backup
> databases, execute "create extension postgis" for all of them, then
> restored the original data from the backups successfully. I am still
> getting this in qGIS logs...
> 2022-09-29T14:38:36 WARNING No PostGIS support in the database.
> 2022-09-29T14:38:36 WARNING Database connection was successful,
> but the accessible tables could not be determined.
> regards
> Simon
> Simon Greener
> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia
> (m) +61 418 396 391
> (w)www.spdba.com.au <http://www.spdba.com.au>
> (m)simon at spdba.com.au
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Simon Greener
(m) +61 418 396 391
(w)www.spdba.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220930/5e1058e2/attachment.htm>
