[postgis-users] [postgis-devel] Error Upgrading PostGIS 2.5.4 to 3.1.2
    Nikhil Shetty
    nikhil.dba04 at gmail.com
    Mon Apr 17 02:24:17 PDT 2023
Hi Sandro,
Thank you, I will try the workaround
BUT I'm wondering: why would you want to upgrade to 3.1.2 when the
latest PostGIS version in the 3.1 branch is 3.1.8 ?
 -- We started with the upgrade at a time when 3.1.2 was the latest
version. We will try to add the newer version in future upgrades.
Thanks,
Nikhil
On Fri, Apr 14, 2023 at 5:08 PM Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Apr 14, 2023 at 01:29:02PM +0530, Nikhil Shetty wrote:
> > geo=# alter extension postgis update to '3.1.2';
> > ERROR:  could not access file "$libdir/postgis-2.5": No such file or
> directory
> > We removed the old 2.5.4 packages and installed 3.1.2
> > ls -l /usr/pgsql-10/lib | grep postgis
> > -rwxr-xr-x 1 root root 1047128 Jun 29  2021 *postgis*-3.so
> > -rwxr-xr-x 1 root root  850416 Jun 29  2021 *postgis*_raster-3.so
> > -rwxr-xr-x 1 root root  435656 Jun 29  2021 *postgis*_sfcgal-3.so
> > -rwxr-xr-x 1 root root  565008 Jun 29  2021 *postgis*_topology-3.so
> A quick workaround should be something along these lines:
>   for f in $('ls' /usr/pgsql-10/lib/*postgis*-3.so); do
>     l=$(echo "$f" | sed 's/-3\./2.5./')
>     ln -vs "$f" "$l"
>   done
> I'm asking because according to the NEWS file the bug you report
> was fixed in 3.1.5:
>   https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.1.5/NEWS#L12
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230417/258712bd/attachment.htm>
