[postgis-users] Size of geometry issue
Regina Obe lr at pcorp.us
Tue Aug 8 14:55:49 PDT 2023
Are you running GEOS > 3.9.
If so maybe ST_Union with a gridsize might work better for you needs over ST_Collect
https://postgis.net/docs/ST_Union.html
There are also a number of precision reduction functions
https://postgis.net/docs/ST_SimplifyPreserveTopology.html
https://postgis.net/docs/ST_SnapToGrid.html
come to mind
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shaozhong SHI
Sent: Tuesday, August 8, 2023 5:46 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Size of geometry issue
St_collect is used and size issue may cause the problem.
If just their relationship needs to be depicted, how can the size of geometry be reduced?
Regards,
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230808/747710bf/attachment.htm>
