[postgis-users] PostGIS 3.4 on PG 16 observations
Gandalf the Gray pjduplooy.gis at gmail.com
Mon Aug 14 04:02:17 PDT 2023
Hi
Sorry, I also meant to ask what is the purpose of the extra info when one
does a select postgis_full_version(), like NETWORK_ENABLED=OFF,
URL_ENDPOINT, USER_WRITEABLE_DIRECTORY?  DATABASE_PATH I get.  Or should I
ask postgres mailing list?
Pieter
On Mon, Aug 14, 2023 at 12:56 PM Gandalf the Gray <pjduplooy.gis at gmail.com>
wrote:
> Hi
> I have made the following observations regarding PostGIS 3.4 on PG 16
> using the archives on buildbot for Winnie.
> PostGIS proper works perfectly.
> PgRouting does not appear in the list of extensions while using PGAdmin,
> although it is installable using the command line.
> H3_postgis is not installable at all, and gives me the following error:
> could not access file "h3_postgis": No such file or directory
> H3 is however , installable.
> Regards
> Pieter
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230814/f4a24207/attachment.htm>
