[postgis-users] PostGIS 3.4.0 binaries and Installers for Windows PostgreSQL 12-16
atanga MARCELIUS
marx407 at yahoo.ca
Sun Aug 20 05:48:37 PDT 2023
Hello Everyone,we am trying to upgrade postgresql9.6 to postgresql 14 and postgis with below steps followingthe postgis compartibility with postgis.
postgres 9.6( postgis 2.3) -> postgres 10 ( postgis 2.3) ( postgres upgrade)
postgres 10 (postgis 2.3) -> postgres 10 (postgis 2.5) ( postgis upgrade)
postgres 10 ( postgis 2.5) -> postgres 11 ( postgis 2.5) ( postgres upgrade)
postgres 11 ( postgis 2.5) -> postgres 11 ( postgis 3.1) ( postgis upgrade)
postgres 11 ( postgis 3.1) -> postgres 14 ( postgis 3.1) ( postgres upgrade)
So what i have done so far is .
1) First i have upgrade postgres 9.6 with postgis 2.3 to postgres 10 with same postgis 2.3. i installed postgres 10 and installed postgres contrib, then for postgis, i copied the postgis libraries from postgres 9.6 to postgres 10 and also installed "yum install postgis23_10" and i think its the compartible postgis 2.3 for version 10 i installed made the pg_upgrade successful and as postgres 9.6 and 10 postgis functions are compartible. >>>>>>So from postgres 9.6 to 10, i was able to run pg_upgrade successfully. 2) Upgrading from postgres 10 to postgres 11 but have to upgrade postgis 2.3 to postgis 2.5 as those are compartible.
So far postgres 10 already has postgis23_10 installed as i did when i wanted to upgrade from 9.6 to 10.So i went ahead and installed "yum install postgresql11-contrib and yum install postgis25_11" so as to see if i canhave an upgrade path from postgis 2.3 to 2.5 as postgres 11 is compartible with postgis 2.5.
Upgrade of Postgis will fail and reading from postgis website i see not all can be upgraded using the alter command.
\dx that list entensions will not bring up postgis.
xxxxx=# \dx List of installed extensions Name | Version | Schema | Description --------------------+---------+------------+-------------------------------------------------------------- hstore | 1.4 | public | data type for storing sets of (key, value) pairs pg_repack | 1.4.6 | public | Reorganize tables in PostgreSQL databases with minimal locks pg_stat_statements | 1.6 | public | track execution statistics of all SQL statements executed pgcrypto | 1.3 | public | cryptographic functions pgstattuple | 1.5 | public | show tuple-level statistics plpgsql | 1.0 | pg_catalog | PL/pgSQL procedural language uuid-ossp | 1.1 | public | generate universally unique identifiers (UUIDs)(7 rows)
xxxxx=# SELECT postgis_full_version();NOTICE: Function postgis_gdal_version() not found. Is raster support enabled and rtpostgis.sql installed?NOTICE: Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?NOTICE: Function postgis_raster_lib_version() not found. Is raster support enabled and rtpostgis.sql installed? postgis_full_version --------------------------------------------------------------------------------------------------------------------------------------------------------------- POSTGIS="2.3.7 r16523" GEOS="3.9.2-CAPI-1.14.3" PROJ="Rel. 4.9.3, 15 August 2016" LIBXML="2.9.1" LIBJSON="0.11" (core procs from "2.3.2 r15302" need upgrade)(1 row)
xxxxx=# SELECT postgis_extensions_upgrade();ERROR: function postgis_extensions_upgrade() does not existLINE 1: SELECT postgis_extensions_upgrade(); ^HINT: No function matches the given name and argument types. You might need to add explicit type casts.
xxxxx=# ALTER EXTENSION postgis UPDATE TO '2.5.5';ERROR: extension "postgis" does not existxxxxx=# ALTER EXTENSION postgis UPDATE TO '2.5';ERROR: extension "postgis" does not existxxxxxx=# ALTER EXTENSION postgis UPDATE;ERROR: extension "postgis" does not exist
PLEASE CAN SOMEONE ASSIST TO EXPLAIN MY OPTIONS TO UPGRADE POSTGIS?
THANKS ALL.
--------------------------------------------- Marcelius AtangaTel: +13025384841
Sent from Yahoo Mail on Android
On Sat, Aug 19, 2023 at 8:44 PM, Regina Obe<lr at pcorp.us> wrote:
I've published the installers for PostGIS 3.4.0 bundle for Windows PostgreSQL 12, 13, 14, 15, and 16
Details on this page:
https://postgis.net/documentation/getting_started/install_windows/released_versions/
Extensions included are:
PostGIS 3.4.0 project: postgis, postgis_raster, postgis_topology, postgis_tiger_geocoder, postgis_sfcgal, address_standardizer, address_standardizer_data_us
pgRouting: pgrouting 3.5.0
h3-pg 4.1.3: h3, h3_postgis
pgpointcloud : 1.2.4 pointcloud, pointcloud_postgis
ogr_fdw: 1.1.4
mobilitydb: 1.1.0alpha
enabling in databases detailed here - https://postgis.net/documentation/getting_started/install_windows/enabling_postgis/
Let me know if you run into any issues.
Thanks,
Regina
postgis-users mailing list
postgis-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230820/dd68c659/attachment.htm>
