[postgis-users] [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
    Regina Obe
    lr at pcorp.us
    Wed Aug 23 11:11:36 PDT 2023
3.1.2 is not the latest stable release for 3.1, so you really shouldn’t be using that.  The 3.1.2 is before the PostgreSQL security vulnerability patches for example and numerous bugs have been fixed since then.
Latest 3.1 is 3.1.9
https://postgis.net/2023/05/PostGIS-3.3.3-3.2.5-3.1.9-3.0.9-Patch-Releases/
News specific for 3.1 - https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.9/NEWS
I would say the same holds true for PostgreSQL 13.12 is the latest stable, so not sure why you are trying to use a version several micro updates behind
https://www.postgresql.org/about/news/postgresql-154-149-1312-1216-1121-and-postgresql-16-beta-3-released-2689/
Hope that helps,
Regina
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nikhil Shetty
Sent: Wednesday, August 23, 2023 2:02 PM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>; postgis-users at lists.osgeo.org
Subject: [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
Hi Team,
We want to know if there are any open/known issues that we may face post-migration of the Postgres database  instance  with PostGIS enabled from centos7/RHEL7/OEL7 to RHEL8.
We came across one issue regarding collation(https://wiki.postgresql.org/wiki/Locale_data_changes), the solution for which is to reindex or use logical replication. This is not related to PostGIS but still a concern causing index corruption
In a similar way, we want to understand if there are any other known issues related to PostGIS that should be taken care of
PostgreSQL : 13.6
PostGIS : 3.1.2
Thanks and Regards,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230823/79fce523/attachment.htm>
