[postgis-users] DMARC config
Greg Troxel
gdt at lexort.com
Thu Aug 24 05:18:24 PDT 2023
The From: field is ok:
DKIM failed both on ingress to osgeo and on delivery to me. Feel free
to send me a private message and I'll let you know how my server
processed your DKIM headers.
Authentication-Results: s1.lexort.com; dkim=fail reason="signature verification failed" (2048-bit key) header.d=norbit.de header.i=@norbit.de header.b=bpeihA1U
Authentication-Results: lists.osgeo.org; dkim=fail reason="signature verification failed" (2048-bit key; unprotected) header.d=norbit.de header.i=@norbit.de header.b="bpeihA1U"; dkim-atps=neutral
The reply-to field is set incorrectly:
Reply-To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
which will cause the "reply" action of an MUA to send what is intended
to be a private message to the list. (Unless that MUA is configured to
ignore Reply-To becuase of the prevalance of this bad behavior!)
There is a spurious MIME part at the end, which explains my server
getting a DKIM signature failure, but at least it is outside of your
multipart/signed, on which PGP signature verification was successful.
Often list modifications break OpenPGP signatures.
--===============6744765610951868642==
Content-Type: text/plain; charset="us-ascii"
MIME-Version: 1.0
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
--===============6744765610951868642==--
