[postgis-users] [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
Nikhil Shetty
nikhil.dba04 at gmail.com
Tue Aug 29 12:08:22 PDT 2023
Got it, Thanks Regina!
On Tue, Aug 29, 2023 at 6:55 PM Regina Obe <lr at pcorp.us> wrote:
> I doubt we’ll be ending support of 3.1 in 2024 but we haven’t voted on it.
> We still need to EOL 3.0 too which we haven’t voted on either.
> So 3.0 will most likely be in 2023. 3.1 probably not because we don’t
> like to EOL two versions in 1 year.
> Also if there is no pressing reason to EOL, e.g the code hasn’t changed so
> much that we can’t apply security patches without rewriting the patch, we
> aren’t in that much of a rush.
> So too things that force us to EOL
> 1. Patches are harder to Apply
> 2. We no longer have CI bots that can comfortably test all the PGs
> that were supported by that minor
> Thanks,
> Regina
> *From:* Nikhil Shetty <nikhil.dba04 at gmail.com>
> *Sent:* Tuesday, August 29, 2023 8:56 AM
> *To:* Regina Obe <lr at pcorp.us>
> *Cc:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-devel] [postgis-users] PostGIS Known Issues :
> Hi Regina,
> One quick question, as per doc regd EOL
> The PostGIS project strives to support each minor version of PostGIS for
> 2-4 years after initial release and at the very least until the lowest
> PostgreSQL version supported by the PostGIS minor version is EOL’d
> For PostGIS 3.1(released in 2020), the support will end in 2024? or after
> PostgreSQL 11 EOL i.e 2023(Next 2-3 months) ?
> I was thinking should we go for minor version upgrade (3.1.9) or move
> directly to major version (3.2 or 3.3) (will require more stringent tests)
> Thanks,
> Nikhil
> On Fri, Aug 25, 2023 at 8:06 PM Nikhil Shetty <nikhil.dba04 at gmail.com>
> wrote:
> Hi Regina, Greg,
> Thank you for the detailed explanation
> We will upgrade PostGIS to latest release and then migrate to RHEL8
> We will share with the community if there are any findings
> Thanks,
> Nikhil
> On Fri, 25 Aug 2023 at 19:37, Regina Obe <lr at pcorp.us> wrote:
> Nikhil,
> As Greg had stated in a related post, I’d advice not using a micro we no
> longer support. I already pointed at all the issues with those here -
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/stable-3.1/NEWS
> The BIG known issue is we can’t help you if anything goes wrong cause we
> don’t support PostGIS 3.1.2 and I honestly can’t remember that far back in
> time (2 years ago).
> That’s 7 unsupported micro releases ago paired with a PostgreSQL version
> that is 7 micro releases behind the latest stable PostgreSQL 13. Yes I
> suspect you’ll have lots of issues.
> Any issues you run into using PostGIS 3.1.2 instead of any of our
> supported micros - https://postgis.net/development/source_code/
> are on you. PostgreSQL group will have the same answer if you ask them if
> you have issues with a micro they stopped supporting a while ago.
> If you report an issue to either PostGIS or PostgreSQL groups, our answer
> will be “Upgrade to the latest micro to make sure it’s not an issue we
> already solved” or go ask the group (e.g. vendor)
> who is asking you to run an out of date version of software.
> I also have no idea whether you are packaging your own or getting it from
> a distribution.
> Most of the issues that arise are how you package the dependencies, which
> versions you are running with and how it conflicts with stuff you already
> have installed or applications that depend on it.
> I’m also unclear what version of PostGIS you are upgrading from. Telling
> me you are coming from RHEL7 tells me nothing since I have much newer minor
> versions of PostGIS running on RHEL 7 systems.
> You will need to report at the very least:
> SELECT version(), postgis_full_version();
> From your RHEL7 system and if you are doing a pg_dump and pg_restore or
> not.
> Generally running pg_dump / pg_restore is slowest way to upgrade but least
> hassle of issues so easiest to go if you have few databases or a small
> database.
> Doing a replication and then pg_upgrade after is the fastest way to
> upgrade and what I do for databases in the high gigabytes or terabytes
> (least amount of downtime), but there are lots of gotchas with that such as
> What I mentioned here:
> https://www.bostongis.com/blog/index.php?/archives/273-Using-pg_upgrade-to-upgrade-PostgreSQL-9.3-PostGIS-2.1-to-PostgreSQL-11-2.5-on-Yum.html
> There are also often issues that arise with PROJ, but those should be less
> so since you are not trying to upgrade on the same system.
> Hope that helps,
> Regina
> *From:* postgis-devel <postgis-devel-bounces at lists.osgeo.org> *On Behalf
> Of *Nikhil Shetty
> *Sent:* Friday, August 25, 2023 4:03 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Cc:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Hi Regina,
> Please let us know if upgrading to RHEL8 with 3.1.2 would be an issue or
> any other known issues with PostGIS
> Thanks,
> Nikhil
> On Thu, 24 Aug 2023 at 08:24, Nikhil Shetty <nikhil.dba04 at gmail.com>
> wrote:
> Hi Regina,
> We do have plans to upgrade both Postgres and PostGIS to higher versions
> but currently we are focusing on OS upgrade to RHEL8
> Do you think being on PostGIS 3.1.2 will impact OS upgrade? Are there any
> known issues
> Thanks,
> Nikhil
> On Wed, 23 Aug 2023 at 23:41, Regina Obe <lr at pcorp.us> wrote:
> 3.1.2 is not the latest stable release for 3.1, so you really shouldn’t be
> using that. The 3.1.2 is before the PostgreSQL security vulnerability
> patches for example and numerous bugs have been fixed since then.
> Latest 3.1 is 3.1.9
> https://postgis.net/2023/05/PostGIS-3.3.3-3.2.5-3.1.9-3.0.9-Patch-Releases/
> News specific for 3.1 -
> https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.9/NEWS
> I would say the same holds true for PostgreSQL 13.12 is the latest stable,
> so not sure why you are trying to use a version several micro updates behind
> https://www.postgresql.org/about/news/postgresql-154-149-1312-1216-1121-and-postgresql-16-beta-3-released-2689/
> Hope that helps,
> Regina
> *From:* postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Nikhil Shetty
> *Sent:* Wednesday, August 23, 2023 2:02 PM
> *To:* PostGIS Development Discussion <postgis-devel at lists.osgeo.org>;
> *Subject:* [postgis-devel] PostGIS Known Issues : OEL7 to RHEL8 Upgrade
> Hi Team,
> We want to know if there are any open/known issues that we may face
> post-migration of the Postgres database instance with PostGIS enabled
> from centos7/RHEL7/OEL7 to RHEL8.
> We came across one issue regarding collation(
> https://wiki.postgresql.org/wiki/Locale_data_changes), the solution for
> which is to reindex or use logical replication. This is not related to
> PostGIS but still a concern causing index corruption
> In a similar way, we want to understand if there are any other known
> issues related to PostGIS that should be taken care of
> PostgreSQL : 13.6
> PostGIS : 3.1.2
> Thanks and Regards,
> Nikhil
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230830/f32a02db/attachment.htm>
