[postgis-users] Stuck with upgrade from postgresql 9.6 to postgresql 14 due to postgis2.3
atanga MARCELIUS
marx407 at yahoo.ca
Mon Aug 28 23:55:37 PDT 2023
Hello Sandro, Thanks for your support.
Please here are the out put to the queries you suggested.
I have also attached the output in text document in a clearer format.
My main concern here is how to manage the upgrade path from postgis 2.3 in postgresql 9.6 to a compactible version of postgis in postgresql14 given that postgis 2.3 was hard install(using source code) and given my environmental challenges I do not want to do a dump and restore?
1.
postgres=# SELECT postgis_full_version(); postgis_full_version ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- POSTGIS="2.3.7 r16523" PGSQL="100" GEOS="3.9.2-CAPI-1.14.3" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" RASTER(1 row)
2.postgres=# SELECT oid::regprocedure,probin FROM pg_catalog.pg_proc WHERE proname LIKE 'postgis_%version'; oid | probin ------------------------------+----------------------- postgis_version() | $libdir/postgis-2.3 postgis_liblwgeom_version() | $libdir/postgis-2.3 postgis_proj_version() | $libdir/postgis-2.3 postgis_lib_version() | $libdir/postgis-2.3 postgis_geos_version() | $libdir/postgis-2.3 postgis_svn_version() | $libdir/postgis-2.3 postgis_libxml_version() | $libdir/postgis-2.3 postgis_full_version() | postgis_libjson_version() | $libdir/postgis-2.3 postgis_raster_lib_version() | $libdir/rtpostgis-2.3 postgis_gdal_version() | $libdir/rtpostgis-2.3(11 rows)
postgres=#
--------------------------------------------- Marcelius AtangaTel: +13025384841
CallSend SMSCall from mobileAdd to SkypeYou'll need Skype CreditFree via Skype
On Wednesday, August 23, 2023 at 11:31:11 AM EDT, Sandro Santilli <strk at kbt.io> wrote:
On Wed, Aug 23, 2023 at 10:08:23AM +0000, atanga MARCELIUS wrote:
> xxxxx=# ALTER EXTENSION postgis UPDATE TO '2.5.5';
> ERROR: extension "postgis" does not exist
The above message means that database "xxxxx" does not contain
the "postgis extension". This does not necessarely mean it doesn't
contain postgis objects, if you're coming from a very old install
as you seem to be coming from.
What does this query return?
And this one ?
--strk;
Libre GIS consultant/developer
https://strk.kbt.io/services.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230829/a4de36dc/attachment.htm>
