[postgis-users] Complex Overlays
Eloi Ribeiro
mail at eloiribeiro.eu
Thu Aug 31 03:10:13 PDT 2023
Thanks Nicolas! Perfect!
Just for future reference, SQL code after fix:
DROPSEQUENCEIFEXISTS myschema.polys_seq;
DROPTABLEIFEXISTS myschema.polys;
CREATESEQUENCEmyschema.polys_seq;
CREATETABLEmyschema.polys AS
SELECT nextval('myschema.polys_seq') AS gid,
(ST_Dump(ST_Polygonize(geom))).geom
FROM
SELECT ST_Union(ST_Boundary(geom)) AS geom
FROM myschema.complex_circles
) AS t;
ALTERTABLE myschema.polys ADDPRIMARY KEY(gid);
CREATEINDEXpolys_geom_idxON myschema.polys USING gist(geom);
GRANT ALL ONTABLE myschema.polys TO myschema;
GRANTSELECTONTABLE myschema.polys TO myschema_r;
ALTERTABLE myschema.polys ADD COLUMN count INTEGERDEFAULT0;
UPDATE myschema.polys
SET count = p.count
FROM (
SELECT p.gid, count(*)
FROM myschema.polys p
JOIN myschema.complex_circles c
ON ST_Contains(c.geom, ST_PointOnSurface(p.geom))
GROUP BY p.gid
) AS p
WHERE p.gid = polys.gid;
DELETEFROM myschema.polys WHERE count =0;DELETEFROM myschema.polys WHERE ST_Area(geom)/ST_Perimeter(geom) <0.1;
Cheers!
Eloi
------- Original Message -------
On Wednesday, August 30th, 2023 at 19:43, Nicolas Ribot <nicky666 at gmail.com> wrote:
> Hello,
> You could use st_polygonize on the union of the polygons' boundaries to reconstruct all closed linestrings as polygons.
> A spatial join on these polygons could be used to retrieve original polygons information
> select
> st_dump
> st_polygonize
> (geom))).geom
> from
> select
> st_union
> st_boundary
> geom
> as
> geom
> from
> complex_circles
> as
> t
> [Screenshot 2023-08-30 at 19.41.31.png][Screenshot 2023-08-30 at 19.42.47.png]
> Nicolas
> On Wed, 30 Aug 2023 at 18:45, Eloi Ribeiro <mail at eloiribeiro.eu> wrote:
>> Hi all,
>> Did anyone successfully executed the following procedure http://blog.cleverelephant.ca/2019/07/postgis-overlays.html with complex geometries (polygons with holes)?
>> Below the SQL code I am using (read failing). I still get duplicated (overlapped) polygons and some others are just missing in the final layer.
>> Any help would be very much appreciated.
>> Sample data that I'm using: https://eloiribeiro.eu/s/bkoWYyNZJMT8bpW
>> CREATE SEQUENCE boundaries_gid_seq;
>> CREATE TABLE boundaries AS
>> SELECT nextval('boundaries_gid_seq') AS gid,
>> gid AS gid_old,
>> (ST_DumpRings(geom)).path AS path,
>> ((ST_DumpRings(geom)).geom) AS geom
>> FROM complex_circles; -- layer with complex polygons, with holes
>> ALTER TABLE boundaries ADD PRIMARY KEY(gid);
>> CREATE INDEX boundaries_geom_idx ON boundaries USING gist(geom);
>> CREATE SEQUENCE polys_seq;
>> CREATE TABLE polys AS
>> SELECT nextval('polys_seq') AS gid,
>> ((ST_Dump(ST_Polygonize(geom))).geom) AS geom
>> FROM boundaries;
>> ALTER TABLE polys ADD PRIMARY KEY(gid);
>> CREATE INDEX polys_geom_idx ON polys USING gist(geom);
>> ALTER TABLE polys ADD COLUMN count INTEGER DEFAULT 0;
>> ALTER TABLE polys ADD COLUMN codes text;
>> UPDATE polys
>> SET count = p.count,
>> codes = p.array_agg
>> FROM (
>> SELECT p.gid, count(*), array_agg(code)
>> FROM polys p
>> JOIN complex_circles c
>> GROUP BY p.gid
>> ) AS p
>> DELETE FROM polys WHERE count = 0;
>> Software version:
>> SELECT version();
>> "PostgreSQL 12.16 ..."
>> SELECT postgis_full_version();
>> "POSTGIS=""3.1.9 95a641b"" [EXTENSION] PGSQL=""120"" GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1"" LIBXML=""2.9.1"" LIBJSON=""0.11"""
>> Eloi
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230831/866889ce/attachment.htm>
Name: Screenshot 2023-08-30 at 19.41.31.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230831/866889ce/attachment.png>
Name: Screenshot 2023-08-30 at 19.42.47.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230831/866889ce/attachment-0001.png>
