[postgis-users] ST_Intersects on geography in WHERE clause returns wrong results
Claire Palmer clairempalmer at gmail.com
Sat Jul 1 16:18:12 PDT 2023
Dear PostGIS users,
I am running a simple point-in-polygon analysis on Orange County flood zone
polygons.  I noticed that I'm getting some false positives when running
ST_Intersects on geography in the where clause.
My postgis_full_version is:
POSTGIS-"2.4.3 R16312" PGSQL=100 GEOS="3.6.2-CAPI-1.10.2 4d2925d"
PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released 2017/11/20
GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="0.12" LIBROTOBUF="1.2.1" RASTER
The following query should return one flood zone, but instead it's
returning two:
SELECT gid, fld_zone, ST_Intersects(geog_nad83,
'SRID=4269;POINT(-117.876941 33.644253)'::geography)
FROM nfhl.orange_county_s_fld_haz_ar
WHERE ST_Intersects(geog_nad83, 'SRID=4269;POINT(-117.876941
33.644253)'::geography);
It's selecting the polygon the point intersects with, and also the adjacent
polygon.
Here's a visual of the two polygons together with the test point:
[image: Screen Shot 2023-07-01 at 3.58.08 PM.png]
If I remove the where clause and query ST_Intersects for the adjacent
polygon, the result is correctly FALSE:
WHERE gid = 224482;
To test further, I generated 1000 points on a 200 meter buffer around the
test point.  The results can be seen in the following visual.  Some points
return only the polygon they intersect with (grey, green) but others return
an additional adjacent polygon (blue, red):
[image: Screen Shot 2023-07-01 at 4.04.04 PM.png]
Also, I should note that running the same query on geometry does not
introduce any errors.  We'd like to stick with using geography if possible
and were a bit surprised with these false positives.
Does anyone know what's going on?  Does it have to do with the earlier
PostGIS version?  We are planning an upgrade to the latest version, but our
API is stuck for now with the version I posted above.
Any insight as to why the false positives are occurring would be
appreciated!
Thanks,
Claire
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230701/e5db95e0/attachment-0001.htm>
Name: Screen Shot 2023-07-01 at 3.58.08 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230701/e5db95e0/attachment-0002.png>
Name: Screen Shot 2023-07-01 at 4.04.04 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230701/e5db95e0/attachment-0003.png>
