[postgis-users] Problem with Nested Loop in a query with postgis
Anderson Mallmann
a.a.mallmann at gmail.com
Mon Jul 24 19:32:50 PDT 2023
Hi
I restored the backup from pg10 2.5.3 and updated postis to 3.1.7. After
that I upgrade postgres to pg14.
I think that in the first message plan, we forgot to
run postgis_extensions_upgrade in pg14 3.1.7, because now I tested the
query before and after the postgis upgrade, and the plan changed. That
explains the difference from 3.1.7 and 3.1.8.
postgis_full_version | POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="100"
GEOS="3.8.1-CAPI-1.13.3" PROJ="Rel. 7.0.1, May 1st, 2020" GDAL="GDAL 3.0.4,
released 2020/01/28 GDAL_DATA not found" LIBXML="2.9.1" LIBJSON="0.11"
LIBPROTOBUF="1.0.2" RASTER
version | PostgreSQL 10.23 on x86_64-pc-linux-gnu, compiled by
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44), 64-bit
Nested Loop (cost=4.92..12.04 rows=1 width=263) (actual
time=190.398..459.920 rows=416 loops=1)
Output: pols.pol_id, pols.type, pols.kml, json_build_object('type',
'Feature', 'geometry', (st_asgeojson(pols.geom, 15, 0))::jsonb),
pols.status, pols.owner_id, pols.details, pols.creation_date, pols.country,
pols.state, pols.city, pols.label
Buffers: shared hit=1340
-> Unique (cost=4.64..4.65 rows=1 width=3) (actual
time=189.532..189.535 rows=1 loops=1)
Output: s.state, ((s.state)::text)
Buffers: shared hit=478
-> Sort (cost=4.64..4.64 rows=1 width=3) (actual
time=189.531..189.533 rows=1 loops=1)
Sort Key: ((s.state)::text)
Sort Method: quicksort Memory: 25kB
-> Index Scan using states_geography_idx on region.states s
(cost=0.14..4.63 rows=1 width=3) (actual time=188.775..189.492 rows=1
loops=1)
Output: s.state, s.state
Index Cond: (geography(st_transform(s.geom, 4326)) &&
'0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography)
Filter:
(('0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography &&
_st_expand(geography(st_transform(s.geom, 4326)), '15000'::double
precision)) AND _st_dwithin(geography(st_transform(s.geom, 4326)),
'0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography,
'15000'::double precision, true))
Rows Removed by Filter: 1
Buffers: shared hit=475
-> Index Scan using polygons_geography_state_idx on region.polygons
pols (cost=0.28..4.78 rows=1 width=4835) (actual time=0.631..141.758
rows=416 loops=1)
Output: pols.pol_id, pols.type, pols.kml, pols.geom, pols.status,
pols.owner_id, pols.details, pols.creation_date, pols.country, pols.state,
pols.city, pols.label, pols.last_updated
Index Cond: ((geography(pols.geom) &&
'0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography) AND
((pols.details ->> 'state'::text) = (s.state)::text))
Filter:
(((_st_maxdistance('0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geometry,
st_convexhull(pols.geom)) * '111195'::double precision) <= '15000'::double
precision) AND
_st_expand(geography(pols.geom), '15000'::double precision)) AND
_st_dwithin('0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography,
geography(pols.geom), '15000'::double precision, true))
Rows Removed by Filter: 395
Buffers: shared hit=862
Planning time: 27.886 ms
Execution time: 460.116 ms
postgis_full_version | POSTGIS="3.1.7 aafe1ff" [EXTENSION] PGSQL="100"
GEOS="3.9.2-CAPI-1.14.3" PROJ="7.2.1" GDAL="GDAL 3.3.3, released
2021/10/25" LIBXML="2.9.1" LIBJSON="0.11" RASTER
Merge Semi Join (cost=15.83..16.04 rows=1 width=263) (actual
time=601.348..652.897 rows=416 loops=1)
'Feature', 'geometry', (st_asgeojson(pols.geom, 9, 8))::jsonb),
Merge Cond: (((pols.details ->> 'state'::text)) = (s.state)::text)
Buffers: shared hit=1255 read=1881
-> Sort (cost=4.49..4.50 rows=1 width=4835) (actual
time=328.831..328.878 rows=416 loops=1)
pols.city, pols.label, ((pols.details ->> 'state'::text))
Sort Key: ((pols.details ->> 'state'::text))
Sort Method: quicksort Memory: 1314kB
Buffers: shared hit=1168 read=909
region.polygons pols (cost=0.28..4.48 rows=1 width=4835) (actual
time=9.944..328.144 rows=416 loops=1)
pols.state, pols.city, pols.label, (pols.details ->> 'state'::text)
Index Cond: (geography(pols.geom) &&
Filter:
geography(pols.geom), '15000'::double precision, true) AND
precision))
Buffers: shared hit=1162 read=909
-> Sort (cost=11.34..11.36 rows=9 width=3) (actual
time=272.386..272.386 rows=1 loops=1)
Output: s.state
Sort Key: s.state
Buffers: shared hit=87 read=972
-> Seq Scan on region.states s (cost=0.00..11.19 rows=9 width=3)
(actual time=173.108..272.375 rows=1 loops=1)
Output: s.state
Filter: st_dwithin(geography(st_transform(s.geom, 4326)),
Rows Removed by Filter: 26
Planning time: 2.386 ms
Execution time: 653.027 ms
*before run postgis_extensions_upgrade
(procs need upgrade for use with PostgreSQL "140") GEOS="3.9.2-CAPI-1.14.3"
PROJ="7.2.1" GDAL="GDAL 3.3.3, released 2021/10/25" LIBXML="2.9.1"
version | PostgreSQL 14.8 on x86_64-pc-linux-gnu, compiled by
Merge Semi Join (cost=287.90..289.79 rows=1 width=328) (actual
time=511.157..565.637 rows=416 loops=1)
Buffers: shared hit=1275 read=1873 dirtied=1
-> Sort (cost=4.49..4.50 rows=1 width=328) (actual
time=236.170..236.214 rows=416 loops=1)
Buffers: shared hit=1184 read=901 dirtied=1
region.polygons pols (cost=0.29..4.48 rows=1 width=328) (actual
time=9.117..234.960 rows=416 loops=1)
Filter:
precision))
Buffers: shared hit=1178 read=901 dirtied=1
-> Sort (cost=283.41..283.99 rows=233 width=12) (actual
time=274.853..274.853 rows=1 loops=1)
Output: s.state
Sort Key: s.state
Buffers: shared hit=91 read=972
-> Seq Scan on region.states s (cost=0.00..274.25 rows=233
width=12) (actual time=174.226..274.842 rows=1 loops=1)
Output: s.state
Query Identifier: -3917083104069499193
Planning:
Buffers: shared hit=441 read=27
Planning Time: 2.431 ms
Execution Time: 566.361 ms
*after run postgis_extensions_upgrade
postgis_full_version | POSTGIS="3.1.7 aafe1ff" [EXTENSION] PGSQL="140"
Nested Loop Semi Join (cost=0.68..111.51 rows=1 width=328) (actual
time=155.732..55359.680 rows=416 loops=1)
Join Filter: ((pols.details ->> 'state'::text) = (s.state)::text)
Buffers: shared hit=73020
pols (cost=0.41..55.77 rows=1 width=328) (actual time=0.158..195.166
rows=416 loops=1)
_st_expand('0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography,
Filter:
(st_dwithin('0101000020E61000009EB7B1D9918E45C082734694F6E636C0'::geography,
precision))
Buffers: shared hit=836
(cost=0.27..54.38 rows=1 width=12) (actual time=132.415..132.415 rows=1
loops=416)
Output: s.state_code, s.state, s.country, s.geom
Buffers: shared hit=71136
Planning Time: 0.360 ms
Execution Time: 55360.033 ms
Thanks,
Anderson
Em sex., 21 de jul. de 2023 às 01:37, Regina Obe <lr at pcorp.us> escreveu:
> Was this upgrading pg10 from 2.5.3 to 3.0.7?
> I’m more interested in seeing this run in newer PostgreSQL from 12 on.
> There was a lot of stuff that changed in PostgreSQL 12 that affects
> planner behavior.
> Any chance you can recompare your PG 14 3.1.7 vs. 3.1.8?
> The change detailed between 3.1.7 and 3.1.8 did not make any sense to us
> as nothing in the change log between those two versions would account for
> the issue you are describing here.
> Or was that a typo and the issue was between 3.0.7 and 3.1.8? Planner
> changes between 3.0.7 and 3.1.8 is more likely.
> As mentioned, it would really help if when you state your versions, you
> provide output of
> SELECT postgis_full_version(), version();
> Even micro differences between PostgreSQL versions have on rare occasions
> affected planner behavior too.
> Thanks,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Anderson Mallmann
> *Sent:* Thursday, July 20, 2023 5:13 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Problem with Nested Loop in a query with
> postgis
> I restored a backup of this database in pg10 2.5.3 and updated postgis to
> 3.0.7, at first the query used the Merge Semi Join and the performance was
> fine, so I force to use Nested Loop and perforce was dropped.
> So i think our problem was that postgres changed the plan for this
> query and st_dwithin(geography, geography) in loop didn't perform well, but
> I still don't understand why postgres is choosing to run this query with
> Nested Loop.
> I did other tests with a subset of the data and with a similar query using
> nested loop the performance was not good in 2.5 or 3.0.
> I uploaded the subset to this repository
> https://github.com/aamallmann/postgis-region-db if you want to test.
> Em seg., 17 de jul. de 2023 às 16:40, Regina Obe <lr at pcorp.us> escreveu:
> I looked at our list of items between 3.1.7 and 3.1.8
> https://git.osgeo.org/gitea/postgis/postgis/src/branch/stable-3.1/NEWS
> and can’t find any that would cause what you describe below.
> It’s possible whatever was changed we didn’t consider strong enough to put
> in the news.
> I haven’t checked the git repo yet to see what changed.
> Usually these switches in plans are often triggered by changes in costs of
> the functions or just data and it is possible we adjusted some of the costs
> on these functions.
> I was thinking the 10 to 14 switch might have been caused by the function
> instrumentation changes.
> But that wouldn’t explain your experiencing the same issue on 14 3.1.7 vs
> 14 3.1.8
> If you still have both running, can you give us the output
> So we can confirm we are truly comparing only a difference in PostGIS
> version and not the libraries used or PostgreSQL minor version.
> Thanks,
> Regina
> *Sent:* Monday, July 17, 2023 10:23 AM
> *To:* postgis-users at lists.osgeo.org; lviecelli199 at gmail.com;
> torres.glauco at gmail.com
> *Subject:* [postgis-users] Problem with Nested Loop in a query with
> postgis
> Hi,
> Here at the company I work for, we upgraded a postgres database from
> version 10 to 14 and postgis 2.5.3 to 3.3.3 and in a specific query we
> noticed a huge performance decrease between these versions. This query was
> running less than 1s and now it takes more than 50s.
> Now we are trying to figure out what the real problem is and in which
> version this started to happen. Some of our discoveries so far:
> 1) The query runs fine until postgis 3.1.7
> 2) In postgis 3.1.8 the query execution changed from Merge Semi Join to
> Nested Loop Semi Join.
> 3) Running this query on postgis >= 3.1.8 disabling nested loop with “set
> enable_nestloop = false” the query runs as before without any problem.
> We don’t know why the plan changed in postgis >= 3.1.8 to use Nested Loop,
> but even in earlier versions if any query like this uses nested loop, the
> performance drops.
> Query:
> SELECT pols.pol_id, pols.type, kml, json_build_object('type', 'Feature',
> 'geometry', st_asgeojson(pols.geom)::jsonb) as geoJson, pols.status
> pol_status, pols.owner_id pol_owner, pols.details, pols.creation_date as
> pol_creation_date, pols.country as country, pols.state as state, pols.city
> as city, pols.label as label FROM polygons pols WHERE pols.owner_id is null
> AND pols.status = 'ACTIVE' AND pols.type in ('REGION') AND
> pols.details->>'state' in (SELECT s.state FROM states s WHERE
> ST_DWITHIN(Geography(ST_Transform(s.geom,4326)),
> ST_GeographyFromText('POINT(-43.113826 -22.9022)'),'15000')) AND
> (ST_DWithin(ST_GeographyFromText('POINT(-43.113826 -22.9022)'),
> Geography(pols.geom),'15000')) AND
> (ST_MaxDistance(ST_GeomFromText('POINT(-43.113826 -22.9022)', 4326),
> pols.geom) * 111195) <= '15000'
> Here are the explains for this query:
> pg 14 - postgis 3.1.7
> time=529.041..586.241 rows=416 loops=1)
> Buffers: shared hit=3193
> -> Sort (cost=4.49..4.50 rows=1 width=4656) (actual
> time=244.333..244.367 rows=416 loops=1)
> Buffers: shared hit=2131
> region.polygons pols (cost=0.28..4.48 rows=1 width=4656) (actual
> time=10.207..243.079 rows=416 loops=1)
> Filter:
> precision))
> Buffers: shared hit=2125
> time=284.570..284.570 rows=1 loops=1)
> Output: s.state
> Sort Key: s.state
> Buffers: shared hit=1062
> width=3) (actual time=180.759..284.564 rows=1 loops=1)
> Output: s.state
> Query Identifier: -6178717669455780324
> Planning:
> Buffers: shared hit=481
> Planning Time: 31.139 ms
> Execution Time: 586.869 ms
> pg 14 - postgis 3.1.8
> Nested Loop Semi Join (cost=0.67..111.50 rows=1 width=263) (actual
> time=179.622..59918.477 rows=416 loops=1)
> Buffers: shared hit=72116 read=1075
> pols (cost=0.41..55.77 rows=1 width=4656) (actual time=9.477..221.758
> rows=416 loops=1)
> Filter:
> precision))
> Buffers: shared hit=269 read=692
> (cost=0.26..54.37 rows=1 width=3) (actual time=142.676..142.676 rows=1
> loops=416)
> Buffers: shared hit=70988 read=171
> Planning:
> Buffers: shared hit=401 read=45
> Planning Time: 30.729 ms
> Execution Time: 59919.343 ms
> Regards,
> Anderson M.
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230724/ea111162/attachment.htm>
