[postgis-users] need help
Regina Obe
lr at pcorp.us
Fri Mar 17 01:29:13 PDT 2023
I would run
SELECT postgis_extensions_upgrade();
That should do it.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Bekir Niyaz
Sent: Friday, March 17, 2023 3:11 AM
To: postgis-users at lists.osgeo.org; postgis-users-request at lists.osgeo.org
Subject: [postgis-users] need help
Hello all,
I move db servers to newer servers but I misinstalled the new version of
postgis, former posgis version was 3.0.0 but in new servers I realize I
installed 3.3.2, therefore I get some errors deprecated func like
ERROR,0A000,"A stored procedure tried to use deprecated C function
'pgis_geometry_union_finalfn'","Library function
'pgis_geometry_union_finalfn' was deprecated in PostGIS 3.3.2","Consider
running: SELECT postgis_extensions_upgrade()"
Now what do you recommend me to do, should I remove
postgis33_12-3.3.2-1.rhel8.x86_64 package and install postgis30_12.x86_64
or just run "SELECT postgis_extensions_upgrade()" and find alternate
function to deprecated ones?
This is the prod server.
best regards.
thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230317/b5aa215a/attachment.htm>
