[postgis-users] Help to upgrade postgresql10 with postgis 2.5
pham lan
phamlankt at gmail.com
Sat Mar 18 00:37:15 PDT 2023
Hi Regina,
The postgresql.conf and pg_hba.conf for postgres12 are the default one. I
just changed the port to 5433 and all authentication to trust. Nothing
special.
Please find in attachments those files.
Please find the output:
postgres at host:~> psql -p 5433 -d template1 -c "SELECT * FROM pg_extension;"
oid | extname | extowner | extnamespace | extrelocatable | extversion |
extconfig | extcondition
14385 | plpgsql | 10 | 11 | f | 1.0 |
(1 row)
0 postgres at host:~> free -h
total used free shared buff/cache
available
Mem: 15Gi 610Mi 3.5Gi 13Mi 11Gi
14Gi
Swap: 2.0Gi 95Mi 1.9Gi
Let me know if you see something wrong.
Thanks,
Lan
On Sat, Mar 18, 2023 at 7:04 AM Regina Obe <lr at pcorp.us> wrote:
> I’ve never seen that error before.
> It might be some OOM killer getting in the way as it’s failing on
> vacuuming of pg_catalog.pg_proc in template1, which is a really strange
> place to be failing since the template database have pretty much nothing,
> unless you installed some extension in them.
> What does output – is it low?
> free –h
> It might be something in your postgresql.conf or postgresql.auto.conf like
> your maintenance_work_mem is set too high for your server.
> Since you are doing non-link mode pg_upgrade, you should have 2 instances
> off pg now. I think if it got to the point of vacuumdb it’s already loaded
> all the data in the PG12 instance and you can check if everything is there.
> Can you connect to your PostgreSQL 12, you might have to manually start it
> up
> And then see if you can run below without it crashing. That is
> essentially what vacuumdb does:
> psql -p 5433 -d template1 -c "vacuum (analyze,verbose);"
> Also check what extensions you have installed in template1.
> For template1, there is usually only one extension plpgsql.
> If you have more, you might want to drop the others to rule out it’s some
> extension getting in the way.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *pham lan
> *Sent:* Saturday, March 18, 2023 1:21 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Help to upgrade postgresql10 with postgis
> 2.5
> Hi Regina,
> So I tried to pg_upgrade at least from postgresql 10 (postgis 2.5) to
> postgresql 12 (postgis 2.5) and get the following error. Do you have any
> idea why? (I tried this several times, I even pg_basebackup to another
> server with postgresql 10 and pg_upgrade to postgres12 but got the same
> error)
> > /usr/pgsql-12/bin/pg_upgrade -b /usr/pgsql-10/bin/ -B /usr/pgsql-12/bin/
> -d /var/lib/pgsql/10/data/ -D /var/lib/pgsql/12/data/ -p 5432 -P 5433
> Performing Consistency Checks
> Checking cluster versions ok
> Checking database user is the install user ok
> Checking database connection settings ok
> Checking for prepared transactions ok
> Checking for system-defined composite types in user tables ok
> Checking for reg* data types in user tables ok
> Checking for contrib/isn with bigint-passing mismatch ok
> Checking for tables WITH OIDS ok
> Checking for invalid "sql_identifier" user columns ok
> Creating dump of global objects ok
> Creating dump of database schemas
> ok
> Checking for presence of required libraries ok
> Checking for new cluster tablespace directories ok
> If pg_upgrade fails after this point, you must re-initdb the
> new cluster before continuing.
> Performing Upgrade
> Analyzing all rows in the new cluster
> *failure*
> Consult the last few lines of "pg_upgrade_utility.log" for
> the probable cause of the failure.
> Failure, exiting
> 1 postgres at host:~> cat pg_upgrade_utility.log
> pg_upgrade run on Sat Mar 18 06:16:00 2023
> command: "/usr/pgsql-12/bin/pg_dumpall" --host /var/lib/pgsql --port 5432
> --username postgres --globals-only --quote-all-identifiers --binary-upgrade
> -f pg_upgrade_dump_globals.sql >> "pg_upgrade_utility.log" 2>&1
> command: "/usr/pgsql-12/bin/vacuumdb" --host /var/lib/pgsql --port 5433
> --username postgres --all --analyze >> "pg_upgrade_utility.log" 2>&1
> vacuumdb: vacuuming database "postgres"
> vacuumdb: vacuuming database "template1"
> WARNING: terminating connection because of crash of another server process
> DETAIL: The postmaster has commanded this server process to roll back the
> current transaction and exit, because another server process exited
> abnormally and possibly corrupted shared memory.
> HINT: In a moment you should be able to reconnect to the database and
> repeat your command.
> vacuumdb: error: vacuuming of table "pg_catalog.pg_proc" in database
> "template1" failed: server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> Thanks,
> Lan
> On Fri, Mar 17, 2023 at 10:27 AM pham lan <phamlankt at gmail.com> wrote:
> Yes, actually I followed your instructions.
> After drop extension postgis_sfcgal whichs required me to drop cascade 13
> materialized views, the upgrade to postgres15 went well.
> Afterward, I wanted to update the postgis extension:
> ALTER EXTENSION postgis UPDATE;
> it requests me to drop cascade around 200 materialized views. For the
> test DB, I did that, the update to postgis 3.3 went well but afterward, the
> vacuum step failed.
> In the end, I talked to the teams and they can not afford to have those
> materialized views deleted and then being created again by them.
> That's why I wanna ask if there is a simple way of migrating the
> materialized views? I am not familiar with this.
> Thanks,
> Lan
> On Fri, Mar 17, 2023 at 9:26 AM Regina Obe <lr at pcorp.us> wrote:
> You’d probably want to upgrade PostgreSQL too since PostgreSQL 10 is EOL’d.
> Below are some instructions I had written for Centos. Should be more or
> less the same for Redhat.
> https://www.bostongis.com/blog/index.php?/archives/278-Using-pg_upgrade-to-upgrade-PostgreSQL-9.6-PostGIS-2.4-to-PostgreSQL-15-3.3-on-Yum.html
> Behalf Of *pham lan
> *Sent:* Friday, March 17, 2023 3:56 AM
> 2.5
> Hi Regina,
> Thank you for your reply. Below is the output of the command. Do you know
> a good way to migrate all the definitions of materialized views because we
> have a lot of them and they are quite complex?
> # SELECT postgis_full_version(), version();
> version
> POSTGIS="2.5.5" [EXTENSION] PGSQL="100" GEOS="3.9.2-CAPI-1.14.3"
> SFCGAL="1.4.1" PROJ="Rel. 7.2.1, January 1st, 2021" GDAL="GDAL 3.2.3,
> released 2021/04/27" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="
> 1.3.0" TOPOLOGY RASTER | PostgreSQL 10.23 on x86_64-pc-linux-gnu, compiled
> by gcc (GCC) 8.5.0 20210514 (Red Hat 8.5.0-15), 64-bit
> Thanks,
> Lan
> On Thu, Mar 16, 2023 at 2:15 PM Regina Obe <lr at pcorp.us> wrote:
> It depends on what platform you are on.
> Can you output the following from your postgis enabled databases:
> And send us the output of what each says. That will give a clue of at
> least what platform you are running.
> You’ll need to run this on each database you have with postgis installed
> on, as it is possible to have 2 versions of postgis installed in separate
> databases.
> As to whether you’d need to drop and recreate any materialized views, it
> would depend on what functions they are using. If they are using
> deprecated or removed functions, then eventually you will need to drop and
> recreate, but you could do that at a later time. The PostGIS 3+ upgrade
> will notify you of those issues, but generally can just rename the
> functions in use, so you can drop and recreate at a more convenient time.
> For materialized views that take a long time to build, I generally build
> them under a new name, and do a swap after the new one has been built.
> That would reduce the downtime from hours to 1-2 minutes.
> Thanks,
> Regina
> Behalf Of *pham lan
> *Sent:* Wednesday, March 15, 2023 5:00 PM
> *Subject:* [postgis-users] Help to upgrade postgresql10 with postgis 2.5
> Hello,
> I have very less experience with postgres and postgis. However i receive a
> task to upgrade an old database which has postgresql10 with postgis 2.5.
> The database has some extensions: postgis, postgis_sfcgal,
> postgis_topology, raster and have a lot of materialized views which depends
> on functions on postgis and sfcgal libraries. Could someone please instruct
> me to upgrade my postgres DB to a newer postgres and postgis version
> without having to drop all those materialized views? Idealy to postgis 3.x?
> Thanks in advance.
> Best regards
> Lan Pham
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230318/ba6277b0/attachment.htm>
postgres at host:~> psql -p 5433 -d template1 -c "vacuum (analyze,verbose);"
INFO: vacuuming "pg_catalog.pg_statistic"
INFO: scanned index "pg_statistic_relid_att_inh_index" to remove 108 row versions
DETAIL: CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s
INFO: "pg_statistic": removed 108 row versions in 8 pages
INFO: index "pg_statistic_relid_att_inh_index" now contains 422 row versions in 5 pages
DETAIL: 108 index row versions were removed.
0 index pages have been deleted, 0 are currently reusable.
CPU: user: 0.00 s, system: 0.00 s, elapsed: 0.00 s.
INFO: "pg_statistic": found 47 removable, 422 nonremovable row versions in 23 out of 23 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 644
There were 0 unused item identifiers.
Skipped 0 pages due to buffer pins, 0 frozen pages.
0 pages are entirely empty.
INFO: vacuuming "pg_toast.pg_toast_2619"
INFO: scanned index "pg_toast_2619_index" to remove 1 row versions
INFO: "pg_toast_2619": removed 1 row versions in 1 pages
INFO: index "pg_toast_2619_index" now contains 13 row versions in 2 pages
DETAIL: 1 index row versions were removed.
INFO: "pg_toast_2619": found 1 removable, 13 nonremovable row versions in 3 out of 3 pages
INFO: vacuuming "pg_catalog.pg_type"
INFO: "pg_type": found 0 removable, 406 nonremovable row versions in 10 out of 10 pages
There were 179 unused item identifiers.
INFO: vacuuming "pg_toast.pg_toast_1247"
INFO: index "pg_toast_1247_index" now contains 0 row versions in 1 pages
DETAIL: 0 index row versions were removed.
INFO: "pg_toast_1247": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_type"
INFO: "pg_type": scanned 10 of 10 pages, containing 406 live rows and 0 dead rows; 406 rows in sample, 406 estimated total rows
INFO: vacuuming "pg_catalog.pg_foreign_server"
INFO: index "pg_foreign_server_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_foreign_server_name_index" now contains 0 row versions in 1 pages
INFO: "pg_foreign_server": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 645
INFO: vacuuming "pg_toast.pg_toast_1417"
INFO: index "pg_toast_1417_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1417": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_foreign_server"
INFO: "pg_foreign_server": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_authid"
INFO: "pg_authid": found 0 removable, 9 nonremovable row versions in 1 out of 1 pages
INFO: vacuuming "pg_toast.pg_toast_1260"
INFO: index "pg_toast_1260_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1260": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_authid"
INFO: "pg_authid": scanned 1 of 1 pages, containing 9 live rows and 0 dead rows; 9 rows in sample, 9 estimated total rows
INFO: vacuuming "pg_catalog.pg_statistic_ext_data"
INFO: index "pg_statistic_ext_data_stxoid_index" now contains 0 row versions in 1 pages
INFO: "pg_statistic_ext_data": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 646
INFO: vacuuming "pg_toast.pg_toast_3429"
INFO: index "pg_toast_3429_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3429": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_statistic_ext_data"
INFO: "pg_statistic_ext_data": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_user_mapping"
INFO: index "pg_user_mapping_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_user_mapping_user_server_index" now contains 0 row versions in 1 pages
INFO: "pg_user_mapping": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_1418"
INFO: index "pg_toast_1418_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1418": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_user_mapping"
INFO: "pg_user_mapping": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_subscription"
INFO: index "pg_subscription_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_subscription_subname_index" now contains 0 row versions in 1 pages
INFO: "pg_subscription": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_6100"
INFO: index "pg_toast_6100_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_6100": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_subscription"
INFO: "pg_subscription": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_attribute"
INFO: index "pg_attribute_relid_attnam_index" now contains 2913 row versions in 20 pages
4 index pages have been deleted, 4 are currently reusable.
INFO: index "pg_attribute_relid_attnum_index" now contains 2913 row versions in 14 pages
3 index pages have been deleted, 3 are currently reusable.
INFO: "pg_attribute": found 0 removable, 55 nonremovable row versions in 1 out of 53 pages
Skipped 0 pages due to buffer pins, 52 frozen pages.
INFO: analyzing "pg_catalog.pg_attribute"
INFO: "pg_attribute": scanned 53 of 53 pages, containing 2913 live rows and 0 dead rows; 2913 rows in sample, 2913 estimated total rows
INFO: vacuuming "pg_catalog.pg_proc"
INFO: "pg_proc": found 0 removable, 22 nonremovable row versions in 1 out of 77 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 647
Skipped 0 pages due to buffer pins, 76 frozen pages.
INFO: vacuuming "pg_toast.pg_toast_1255"
INFO: index "pg_toast_1255_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1255": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_proc"
INFO: "pg_proc": scanned 77 of 77 pages, containing 2960 live rows and 0 dead rows; 2960 rows in sample, 2960 estimated total rows
INFO: vacuuming "pg_catalog.pg_attrdef"
INFO: index "pg_attrdef_adrelid_adnum_index" now contains 0 row versions in 1 pages
INFO: index "pg_attrdef_oid_index" now contains 0 row versions in 1 pages
INFO: "pg_attrdef": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 648
INFO: vacuuming "pg_toast.pg_toast_2604"
INFO: index "pg_toast_2604_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2604": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_attrdef"
INFO: "pg_attrdef": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_constraint"
INFO: index "pg_constraint_conparentid_index" now contains 2 row versions in 2 pages
INFO: index "pg_constraint_conname_nsp_index" now contains 2 row versions in 2 pages
INFO: index "pg_constraint_conrelid_contypid_conname_index" now contains 2 row versions in 2 pages
INFO: index "pg_constraint_contypid_index" now contains 2 row versions in 2 pages
INFO: index "pg_constraint_oid_index" now contains 2 row versions in 2 pages
INFO: "pg_constraint": found 0 removable, 2 nonremovable row versions in 1 out of 1 pages
INFO: vacuuming "pg_toast.pg_toast_2606"
INFO: index "pg_toast_2606_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2606": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_constraint"
INFO: "pg_constraint": scanned 1 of 1 pages, containing 2 live rows and 0 dead rows; 2 rows in sample, 2 estimated total rows
INFO: vacuuming "pg_catalog.pg_inherits"
INFO: index "pg_inherits_parent_index" now contains 0 row versions in 1 pages
INFO: index "pg_inherits_relid_seqno_index" now contains 0 row versions in 1 pages
INFO: "pg_inherits": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 649
INFO: analyzing "pg_catalog.pg_inherits"
INFO: "pg_inherits": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_index"
INFO: scanned index "pg_index_indrelid_index" to remove 32 row versions
INFO: scanned index "pg_index_indexrelid_index" to remove 32 row versions
INFO: "pg_index": removed 32 row versions in 1 pages
INFO: index "pg_index_indrelid_index" now contains 159 row versions in 2 pages
DETAIL: 32 index row versions were removed.
INFO: index "pg_index_indexrelid_index" now contains 159 row versions in 2 pages
INFO: "pg_index": found 15 removable, 159 nonremovable row versions in 4 out of 4 pages
INFO: analyzing "pg_catalog.pg_index"
INFO: "pg_index": scanned 4 of 4 pages, containing 159 live rows and 0 dead rows; 159 rows in sample, 159 estimated total rows
INFO: vacuuming "pg_catalog.pg_operator"
INFO: index "pg_operator_oid_index" now contains 770 row versions in 5 pages
INFO: index "pg_operator_oprname_l_r_n_index" now contains 770 row versions in 5 pages
INFO: "pg_operator": found 0 removable, 770 nonremovable row versions in 14 out of 14 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 650
INFO: analyzing "pg_catalog.pg_operator"
INFO: "pg_operator": scanned 14 of 14 pages, containing 770 live rows and 0 dead rows; 770 rows in sample, 770 estimated total rows
INFO: vacuuming "pg_catalog.pg_opfamily"
INFO: index "pg_opfamily_am_name_nsp_index" now contains 107 row versions in 2 pages
INFO: index "pg_opfamily_oid_index" now contains 107 row versions in 2 pages
INFO: "pg_opfamily": found 0 removable, 107 nonremovable row versions in 2 out of 2 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 651
INFO: analyzing "pg_catalog.pg_opfamily"
INFO: "pg_opfamily": scanned 2 of 2 pages, containing 107 live rows and 0 dead rows; 107 rows in sample, 107 estimated total rows
INFO: vacuuming "pg_catalog.pg_opclass"
INFO: index "pg_opclass_am_name_nsp_index" now contains 128 row versions in 2 pages
INFO: index "pg_opclass_oid_index" now contains 128 row versions in 2 pages
INFO: "pg_opclass": found 0 removable, 128 nonremovable row versions in 2 out of 2 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 652
INFO: analyzing "pg_catalog.pg_opclass"
INFO: "pg_opclass": scanned 2 of 2 pages, containing 128 live rows and 0 dead rows; 128 rows in sample, 128 estimated total rows
INFO: vacuuming "pg_catalog.pg_am"
INFO: index "pg_am_name_index" now contains 7 row versions in 2 pages
INFO: index "pg_am_oid_index" now contains 7 row versions in 2 pages
INFO: "pg_am": found 0 removable, 7 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 653
INFO: analyzing "pg_catalog.pg_am"
INFO: "pg_am": scanned 1 of 1 pages, containing 7 live rows and 0 dead rows; 7 rows in sample, 7 estimated total rows
INFO: vacuuming "pg_catalog.pg_amproc"
INFO: index "pg_amproc_fam_proc_index" now contains 447 row versions in 4 pages
INFO: index "pg_amproc_oid_index" now contains 447 row versions in 4 pages
INFO: "pg_amproc": found 0 removable, 447 nonremovable row versions in 3 out of 3 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 654
INFO: analyzing "pg_catalog.pg_amproc"
INFO: "pg_amproc": scanned 3 of 3 pages, containing 447 live rows and 0 dead rows; 447 rows in sample, 447 estimated total rows
INFO: vacuuming "pg_catalog.pg_language"
INFO: index "pg_language_name_index" now contains 4 row versions in 2 pages
INFO: index "pg_language_oid_index" now contains 4 row versions in 2 pages
INFO: "pg_language": found 0 removable, 4 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 655
INFO: vacuuming "pg_toast.pg_toast_2612"
INFO: index "pg_toast_2612_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2612": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_language"
INFO: "pg_language": scanned 1 of 1 pages, containing 4 live rows and 0 dead rows; 4 rows in sample, 4 estimated total rows
INFO: vacuuming "pg_catalog.pg_largeobject_metadata"
INFO: index "pg_largeobject_metadata_oid_index" now contains 0 row versions in 1 pages
INFO: "pg_largeobject_metadata": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 656
INFO: analyzing "pg_catalog.pg_largeobject_metadata"
INFO: "pg_largeobject_metadata": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_aggregate"
INFO: index "pg_aggregate_fnoid_index" now contains 136 row versions in 2 pages
INFO: "pg_aggregate": found 0 removable, 136 nonremovable row versions in 2 out of 2 pages
INFO: vacuuming "pg_toast.pg_toast_2600"
INFO: index "pg_toast_2600_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2600": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_aggregate"
INFO: "pg_aggregate": scanned 2 of 2 pages, containing 136 live rows and 0 dead rows; 136 rows in sample, 136 estimated total rows
INFO: vacuuming "pg_catalog.pg_largeobject"
INFO: index "pg_largeobject_loid_pn_index" now contains 0 row versions in 1 pages
INFO: "pg_largeobject": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 657
INFO: analyzing "pg_catalog.pg_largeobject"
INFO: "pg_largeobject": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_statistic_ext"
INFO: index "pg_statistic_ext_relid_index" now contains 0 row versions in 1 pages
INFO: index "pg_statistic_ext_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_statistic_ext_name_index" now contains 0 row versions in 1 pages
INFO: "pg_statistic_ext": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_3381"
INFO: index "pg_toast_3381_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3381": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_statistic_ext"
INFO: "pg_statistic_ext": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_rewrite"
INFO: index "pg_rewrite_oid_index" now contains 126 row versions in 2 pages
INFO: index "pg_rewrite_rel_rulename_index" now contains 126 row versions in 2 pages
INFO: "pg_rewrite": found 0 removable, 126 nonremovable row versions in 12 out of 12 pages
INFO: vacuuming "pg_toast.pg_toast_2618"
INFO: index "pg_toast_2618_index" now contains 249 row versions in 2 pages
INFO: "pg_toast_2618": found 0 removable, 249 nonremovable row versions in 58 out of 58 pages
INFO: analyzing "pg_catalog.pg_rewrite"
INFO: "pg_rewrite": scanned 12 of 12 pages, containing 126 live rows and 0 dead rows; 126 rows in sample, 126 estimated total rows
INFO: vacuuming "pg_catalog.pg_trigger"
INFO: index "pg_trigger_tgconstraint_index" now contains 0 row versions in 1 pages
INFO: index "pg_trigger_tgrelid_tgname_index" now contains 0 row versions in 1 pages
INFO: index "pg_trigger_oid_index" now contains 0 row versions in 1 pages
INFO: "pg_trigger": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 658
INFO: vacuuming "pg_toast.pg_toast_2620"
INFO: index "pg_toast_2620_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2620": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_trigger"
INFO: "pg_trigger": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_event_trigger"
INFO: index "pg_event_trigger_evtname_index" now contains 0 row versions in 1 pages
INFO: index "pg_event_trigger_oid_index" now contains 0 row versions in 1 pages
INFO: "pg_event_trigger": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_3466"
INFO: index "pg_toast_3466_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3466": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_event_trigger"
INFO: "pg_event_trigger": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_description"
INFO: index "pg_description_o_c_o_index" now contains 4714 row versions in 21 pages
INFO: "pg_description": found 0 removable, 4714 nonremovable row versions in 40 out of 40 pages
INFO: vacuuming "pg_toast.pg_toast_2609"
INFO: index "pg_toast_2609_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2609": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_description"
INFO: "pg_description": scanned 40 of 40 pages, containing 4714 live rows and 0 dead rows; 4714 rows in sample, 4714 estimated total rows
INFO: vacuuming "pg_catalog.pg_cast"
INFO: index "pg_cast_oid_index" now contains 216 row versions in 2 pages
INFO: index "pg_cast_source_target_index" now contains 216 row versions in 2 pages
INFO: "pg_cast": found 0 removable, 216 nonremovable row versions in 2 out of 2 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 659
INFO: analyzing "pg_catalog.pg_cast"
INFO: "pg_cast": scanned 2 of 2 pages, containing 216 live rows and 0 dead rows; 216 rows in sample, 216 estimated total rows
INFO: vacuuming "pg_catalog.pg_enum"
INFO: index "pg_enum_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_enum_typid_label_index" now contains 0 row versions in 1 pages
INFO: index "pg_enum_typid_sortorder_index" now contains 0 row versions in 1 pages
INFO: "pg_enum": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 660
INFO: analyzing "pg_catalog.pg_enum"
INFO: "pg_enum": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_namespace"
INFO: index "pg_namespace_nspname_index" now contains 6 row versions in 2 pages
INFO: index "pg_namespace_oid_index" now contains 6 row versions in 2 pages
INFO: "pg_namespace": found 0 removable, 6 nonremovable row versions in 1 out of 1 pages
INFO: vacuuming "pg_toast.pg_toast_2615"
INFO: index "pg_toast_2615_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2615": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_namespace"
INFO: "pg_namespace": scanned 1 of 1 pages, containing 6 live rows and 0 dead rows; 6 rows in sample, 6 estimated total rows
INFO: vacuuming "pg_catalog.pg_conversion"
INFO: index "pg_conversion_default_index" now contains 132 row versions in 2 pages
INFO: index "pg_conversion_name_nsp_index" now contains 132 row versions in 2 pages
INFO: index "pg_conversion_oid_index" now contains 132 row versions in 2 pages
INFO: "pg_conversion": found 0 removable, 132 nonremovable row versions in 3 out of 3 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 661
INFO: analyzing "pg_catalog.pg_conversion"
INFO: "pg_conversion": scanned 3 of 3 pages, containing 132 live rows and 0 dead rows; 132 rows in sample, 132 estimated total rows
INFO: vacuuming "pg_catalog.pg_depend"
INFO: scanned index "pg_depend_depender_index" to remove 215 row versions
INFO: scanned index "pg_depend_reference_index" to remove 215 row versions
INFO: "pg_depend": removed 215 row versions in 2 pages
INFO: index "pg_depend_depender_index" now contains 7601 row versions in 34 pages
DETAIL: 215 index row versions were removed.
INFO: index "pg_depend_reference_index" now contains 7601 row versions in 35 pages
INFO: "pg_depend": found 111 removable, 7601 nonremovable row versions in 57 out of 57 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 662
INFO: analyzing "pg_catalog.pg_depend"
INFO: "pg_depend": scanned 57 of 57 pages, containing 7601 live rows and 0 dead rows; 7601 rows in sample, 7601 estimated total rows
INFO: vacuuming "pg_catalog.pg_database"
INFO: "pg_database": found 0 removable, 3 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 663
INFO: vacuuming "pg_toast.pg_toast_1262"
INFO: index "pg_toast_1262_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1262": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_database"
INFO: "pg_database": scanned 1 of 1 pages, containing 3 live rows and 0 dead rows; 3 rows in sample, 3 estimated total rows
INFO: vacuuming "pg_catalog.pg_db_role_setting"
INFO: index "pg_db_role_setting_databaseid_rol_index" now contains 0 row versions in 1 pages
INFO: "pg_db_role_setting": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 664
INFO: vacuuming "pg_toast.pg_toast_2964"
INFO: index "pg_toast_2964_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2964": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_db_role_setting"
INFO: "pg_db_role_setting": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_tablespace"
INFO: "pg_tablespace": found 0 removable, 2 nonremovable row versions in 1 out of 1 pages
INFO: vacuuming "pg_toast.pg_toast_1213"
INFO: index "pg_toast_1213_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1213": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_tablespace"
INFO: "pg_tablespace": scanned 1 of 1 pages, containing 2 live rows and 0 dead rows; 2 rows in sample, 2 estimated total rows
INFO: vacuuming "pg_catalog.pg_pltemplate"
INFO: "pg_pltemplate": found 0 removable, 8 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 665
INFO: vacuuming "pg_toast.pg_toast_1136"
INFO: index "pg_toast_1136_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_1136": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_pltemplate"
INFO: "pg_pltemplate": scanned 1 of 1 pages, containing 8 live rows and 0 dead rows; 8 rows in sample, 8 estimated total rows
INFO: vacuuming "pg_catalog.pg_auth_members"
INFO: "pg_auth_members": found 0 removable, 3 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 666
INFO: analyzing "pg_catalog.pg_auth_members"
INFO: "pg_auth_members": scanned 1 of 1 pages, containing 3 live rows and 0 dead rows; 3 rows in sample, 3 estimated total rows
INFO: vacuuming "pg_catalog.pg_shdepend"
INFO: "pg_shdepend": found 0 removable, 9 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 667
INFO: analyzing "pg_catalog.pg_shdepend"
INFO: "pg_shdepend": scanned 1 of 1 pages, containing 9 live rows and 0 dead rows; 9 rows in sample, 9 estimated total rows
INFO: vacuuming "pg_catalog.pg_shdescription"
INFO: "pg_shdescription": found 0 removable, 3 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 668
INFO: vacuuming "pg_toast.pg_toast_2396"
INFO: index "pg_toast_2396_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2396": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_shdescription"
INFO: "pg_shdescription": scanned 1 of 1 pages, containing 3 live rows and 0 dead rows; 3 rows in sample, 3 estimated total rows
INFO: vacuuming "pg_catalog.pg_ts_config"
INFO: index "pg_ts_config_cfgname_index" now contains 22 row versions in 2 pages
INFO: index "pg_ts_config_oid_index" now contains 22 row versions in 2 pages
INFO: "pg_ts_config": found 0 removable, 22 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 669
INFO: analyzing "pg_catalog.pg_ts_config"
INFO: "pg_ts_config": scanned 1 of 1 pages, containing 22 live rows and 0 dead rows; 22 rows in sample, 22 estimated total rows
INFO: vacuuming "pg_catalog.pg_ts_config_map"
INFO: index "pg_ts_config_map_index" now contains 418 row versions in 4 pages
INFO: "pg_ts_config_map": found 0 removable, 418 nonremovable row versions in 3 out of 3 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 670
INFO: analyzing "pg_catalog.pg_ts_config_map"
INFO: "pg_ts_config_map": scanned 3 of 3 pages, containing 418 live rows and 0 dead rows; 418 rows in sample, 418 estimated total rows
INFO: vacuuming "pg_catalog.pg_ts_dict"
INFO: index "pg_ts_dict_dictname_index" now contains 22 row versions in 2 pages
INFO: index "pg_ts_dict_oid_index" now contains 22 row versions in 2 pages
INFO: "pg_ts_dict": found 0 removable, 22 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 671
INFO: vacuuming "pg_toast.pg_toast_3600"
INFO: index "pg_toast_3600_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3600": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_ts_dict"
INFO: "pg_ts_dict": scanned 1 of 1 pages, containing 22 live rows and 0 dead rows; 22 rows in sample, 22 estimated total rows
INFO: vacuuming "pg_catalog.pg_ts_parser"
INFO: index "pg_ts_parser_prsname_index" now contains 1 row versions in 2 pages
INFO: index "pg_ts_parser_oid_index" now contains 1 row versions in 2 pages
INFO: "pg_ts_parser": found 0 removable, 1 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 672
INFO: analyzing "pg_catalog.pg_ts_parser"
INFO: "pg_ts_parser": scanned 1 of 1 pages, containing 1 live rows and 0 dead rows; 1 rows in sample, 1 estimated total rows
INFO: vacuuming "pg_catalog.pg_ts_template"
INFO: index "pg_ts_template_tmplname_index" now contains 5 row versions in 2 pages
INFO: index "pg_ts_template_oid_index" now contains 5 row versions in 2 pages
INFO: "pg_ts_template": found 0 removable, 5 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 673
INFO: analyzing "pg_catalog.pg_ts_template"
INFO: "pg_ts_template": scanned 1 of 1 pages, containing 5 live rows and 0 dead rows; 5 rows in sample, 5 estimated total rows
INFO: vacuuming "pg_catalog.pg_extension"
INFO: index "pg_extension_oid_index" now contains 1 row versions in 2 pages
INFO: index "pg_extension_name_index" now contains 1 row versions in 2 pages
INFO: "pg_extension": found 0 removable, 1 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 674
INFO: vacuuming "pg_toast.pg_toast_3079"
INFO: index "pg_toast_3079_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3079": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_extension"
INFO: "pg_extension": scanned 1 of 1 pages, containing 1 live rows and 0 dead rows; 1 rows in sample, 1 estimated total rows
INFO: vacuuming "pg_catalog.pg_foreign_data_wrapper"
INFO: index "pg_foreign_data_wrapper_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_foreign_data_wrapper_name_index" now contains 0 row versions in 1 pages
INFO: "pg_foreign_data_wrapper": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 675
INFO: vacuuming "pg_toast.pg_toast_2328"
INFO: index "pg_toast_2328_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_2328": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_foreign_data_wrapper"
INFO: "pg_foreign_data_wrapper": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_foreign_table"
INFO: index "pg_foreign_table_relid_index" now contains 0 row versions in 1 pages
INFO: "pg_foreign_table": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_3118"
INFO: index "pg_toast_3118_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3118": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_foreign_table"
INFO: "pg_foreign_table": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_policy"
INFO: index "pg_policy_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_policy_polrelid_polname_index" now contains 0 row versions in 1 pages
INFO: "pg_policy": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_3256"
INFO: index "pg_toast_3256_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3256": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_policy"
INFO: "pg_policy": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_replication_origin"
INFO: index "pg_replication_origin_roiident_index" now contains 0 row versions in 1 pages
INFO: index "pg_replication_origin_roname_index" now contains 0 row versions in 1 pages
INFO: "pg_replication_origin": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_6000"
INFO: index "pg_toast_6000_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_6000": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_replication_origin"
INFO: "pg_replication_origin": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_init_privs"
INFO: index "pg_init_privs_o_c_o_index" now contains 171 row versions in 2 pages
INFO: "pg_init_privs": found 0 removable, 171 nonremovable row versions in 2 out of 2 pages
INFO: vacuuming "pg_toast.pg_toast_3394"
INFO: index "pg_toast_3394_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3394": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_init_privs"
INFO: "pg_init_privs": scanned 2 of 2 pages, containing 171 live rows and 0 dead rows; 171 rows in sample, 171 estimated total rows
INFO: vacuuming "pg_catalog.pg_seclabel"
INFO: index "pg_seclabel_object_index" now contains 0 row versions in 1 pages
INFO: "pg_seclabel": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 676
INFO: vacuuming "pg_toast.pg_toast_3596"
INFO: index "pg_toast_3596_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3596": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_seclabel"
INFO: "pg_seclabel": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_shseclabel"
INFO: index "pg_shseclabel_object_index" now contains 0 row versions in 1 pages
INFO: "pg_shseclabel": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: vacuuming "pg_toast.pg_toast_3592"
INFO: index "pg_toast_3592_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3592": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_shseclabel"
INFO: "pg_shseclabel": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_collation"
INFO: index "pg_collation_oid_index" now contains 1731 row versions in 7 pages
INFO: index "pg_collation_name_enc_nsp_index" now contains 1731 row versions in 11 pages
INFO: "pg_collation": found 0 removable, 1731 nonremovable row versions in 55 out of 55 pages
INFO: vacuuming "pg_toast.pg_toast_3456"
INFO: index "pg_toast_3456_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3456": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_collation"
INFO: "pg_collation": scanned 55 of 55 pages, containing 1731 live rows and 0 dead rows; 1731 rows in sample, 1731 estimated total rows
INFO: vacuuming "pg_catalog.pg_partitioned_table"
INFO: index "pg_partitioned_table_partrelid_index" now contains 0 row versions in 1 pages
INFO: "pg_partitioned_table": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 677
INFO: vacuuming "pg_toast.pg_toast_3350"
INFO: index "pg_toast_3350_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_3350": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_partitioned_table"
INFO: "pg_partitioned_table": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_range"
INFO: index "pg_range_rngtypid_index" now contains 6 row versions in 2 pages
INFO: "pg_range": found 0 removable, 6 nonremovable row versions in 1 out of 1 pages
INFO: analyzing "pg_catalog.pg_range"
INFO: "pg_range": scanned 1 of 1 pages, containing 6 live rows and 0 dead rows; 6 rows in sample, 6 estimated total rows
INFO: vacuuming "pg_catalog.pg_transform"
INFO: index "pg_transform_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_transform_type_lang_index" now contains 0 row versions in 1 pages
INFO: "pg_transform": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 678
INFO: analyzing "pg_catalog.pg_transform"
INFO: "pg_transform": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_sequence"
INFO: index "pg_sequence_seqrelid_index" now contains 0 row versions in 1 pages
INFO: "pg_sequence": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_sequence"
INFO: "pg_sequence": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_publication"
INFO: index "pg_publication_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_publication_pubname_index" now contains 0 row versions in 1 pages
INFO: "pg_publication": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_publication"
INFO: "pg_publication": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_publication_rel"
INFO: index "pg_publication_rel_oid_index" now contains 0 row versions in 1 pages
INFO: index "pg_publication_rel_prrelid_prpubid_index" now contains 0 row versions in 1 pages
INFO: "pg_publication_rel": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_publication_rel"
INFO: "pg_publication_rel": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_subscription_rel"
INFO: index "pg_subscription_rel_srrelid_srsubid_index" now contains 0 row versions in 1 pages
INFO: "pg_subscription_rel": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_subscription_rel"
INFO: "pg_subscription_rel": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "information_schema.sql_features"
INFO: "sql_features": found 0 removable, 716 nonremovable row versions in 8 out of 8 pages
INFO: vacuuming "pg_toast.pg_toast_14234"
INFO: index "pg_toast_14234_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14234": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_features"
INFO: "sql_features": scanned 8 of 8 pages, containing 716 live rows and 0 dead rows; 716 rows in sample, 716 estimated total rows
INFO: vacuuming "information_schema.sql_implementation_info"
INFO: "sql_implementation_info": found 0 removable, 12 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 679
INFO: vacuuming "pg_toast.pg_toast_14239"
INFO: index "pg_toast_14239_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14239": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_implementation_info"
INFO: "sql_implementation_info": scanned 1 of 1 pages, containing 12 live rows and 0 dead rows; 12 rows in sample, 12 estimated total rows
INFO: vacuuming "information_schema.sql_parts"
INFO: "sql_parts": found 0 removable, 9 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 680
INFO: vacuuming "pg_toast.pg_toast_14254"
INFO: index "pg_toast_14254_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14254": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_parts"
INFO: "sql_parts": scanned 1 of 1 pages, containing 9 live rows and 0 dead rows; 9 rows in sample, 9 estimated total rows
INFO: vacuuming "information_schema.sql_languages"
INFO: "sql_languages": found 0 removable, 4 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 681
INFO: vacuuming "pg_toast.pg_toast_14244"
INFO: index "pg_toast_14244_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14244": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_languages"
INFO: "sql_languages": scanned 1 of 1 pages, containing 4 live rows and 0 dead rows; 4 rows in sample, 4 estimated total rows
INFO: vacuuming "information_schema.sql_sizing"
INFO: "sql_sizing": found 0 removable, 23 nonremovable row versions in 1 out of 1 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 682
INFO: vacuuming "pg_toast.pg_toast_14259"
INFO: index "pg_toast_14259_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14259": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_sizing"
INFO: "sql_sizing": scanned 1 of 1 pages, containing 23 live rows and 0 dead rows; 23 rows in sample, 23 estimated total rows
INFO: vacuuming "pg_catalog.pg_class"
INFO: "pg_class": found 0 removable, 395 nonremovable row versions in 11 out of 11 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 683
There were 428 unused item identifiers.
INFO: analyzing "pg_catalog.pg_class"
INFO: "pg_class": scanned 11 of 11 pages, containing 395 live rows and 0 dead rows; 395 rows in sample, 395 estimated total rows
INFO: vacuuming "information_schema.sql_sizing_profiles"
INFO: "sql_sizing_profiles": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 684
INFO: vacuuming "pg_toast.pg_toast_14264"
INFO: index "pg_toast_14264_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14264": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_sizing_profiles"
INFO: "sql_sizing_profiles": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "pg_catalog.pg_amop"
INFO: index "pg_amop_fam_strat_index" now contains 715 row versions in 5 pages
INFO: index "pg_amop_opr_fam_index" now contains 715 row versions in 5 pages
INFO: index "pg_amop_oid_index" now contains 715 row versions in 4 pages
INFO: "pg_amop": found 0 removable, 715 nonremovable row versions in 6 out of 6 pages
INFO: analyzing "pg_catalog.pg_amop"
INFO: "pg_amop": scanned 6 of 6 pages, containing 715 live rows and 0 dead rows; 715 rows in sample, 715 estimated total rows
INFO: vacuuming "pg_catalog.pg_default_acl"
INFO: index "pg_default_acl_role_nsp_obj_index" now contains 0 row versions in 1 pages
INFO: index "pg_default_acl_oid_index" now contains 0 row versions in 1 pages
INFO: "pg_default_acl": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
DETAIL: 0 dead row versions cannot be removed yet, oldest xmin: 685
INFO: vacuuming "pg_toast.pg_toast_826"
INFO: index "pg_toast_826_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_826": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "pg_catalog.pg_default_acl"
INFO: "pg_default_acl": scanned 0 of 0 pages, containing 0 live rows and 0 dead rows; 0 rows in sample, 0 estimated total rows
INFO: vacuuming "information_schema.sql_packages"
INFO: "sql_packages": found 0 removable, 10 nonremovable row versions in 1 out of 1 pages
INFO: vacuuming "pg_toast.pg_toast_14249"
INFO: index "pg_toast_14249_index" now contains 0 row versions in 1 pages
INFO: "pg_toast_14249": found 0 removable, 0 nonremovable row versions in 0 out of 0 pages
INFO: analyzing "information_schema.sql_packages"
INFO: "sql_packages": scanned 1 of 1 pages, containing 10 live rows and 0 dead rows; 10 rows in sample, 10 estimated total rows
VACUUM
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230318/ba6277b0/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230318/ba6277b0/attachment-0001.obj>
