[postgis-users] improve query - summarize building count and area on each parcel
    Marcin Mionskowski
    mionskowskimarcin at gmail.com
    Sun Mar 26 23:33:37 PDT 2023
In my "explain tests", made on much smaller tables, I get 500 times smaller
costs only by changing LEFT JOIN to "regular" JOIN.
pon., 27 mar 2023 o 01:07 Raj Talati <rajtalati at gmail.com> napisał(a):
> I prefer doing insert instead of update if we doing all rows update :) so
> create New table with new table and copy from old and later drop it you can
> go without index and do index later after copy. Postgres update is delete
> and insert internally and direct big update will bloat table.
> Other thing you can do multi thread if you have 16 core with nothing else
> can go 12-14 threads updates which can do portion of your big table easy if
> no good criteria can be mod function on PK
> Hope this helps .
> Raj T
> On Sun, Mar 26, 2023 at 6:54 PM karsten <karsten at terragis.net> wrote:
>> Hi All,
>> I have two tables,  a parcel (polygon) table and a building
>> (polygon) table in a PostGIS db.
>> There are about 1 million parcels and over a million buildings in these
>> tables ...
>> I have set gist indexes on both and clustered each on a geohash, pkey is
>> set on objectid.
>> I would like to fill 2 additional columns for the parcels layer to have
>> the number of building on each parcel (building_count) and the summed up
>> area of all those building footprints (building_fp).
>> Below is an update query but it is extremely lengthy and inefficient (on
>> a beefy 16 core Ubuntu server with 128 GB tons of RAM) : I had to stop an
>> after running 3 days when it was not finished ...
>> I am wondering if anyone has an idea how to make it more efficient ?
>> This is the query:
>> UPDATE parcels p SET
>> building_count = subquery.num,
>> building_fp = subquery.sumarea
>> from
>> (select objectid, count(*) as num, sum(st_area(b.geom)) as sumarea FROM
>> parcels p
>> left join buildings b on st_intersects(p.geom,st_centroid(b.geom)) group
>> by objectid ) subquery
>> where p.objectid = subquery.objectid ;
>> Any suggestions ?
>> Cheers
>> Karsten Vennemann
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230327/3b810e99/attachment.htm>
