[postgis-users] [postgis-devel] Error Upgrading PostGIS 2.5.4 to 3.1.2
Sandro Santilli
strk at kbt.io
Fri May 12 03:13:29 PDT 2023
On Tue, May 09, 2023 at 03:59:13PM +0530, Nikhil Shetty wrote:
> I installed 3.1.5 but we are still having the same issue when upgrading
> dbname=# alter extension postgis update ;
> ERROR: cannot drop function st_distance(geography,geography) because other
> objects depend on it
> DETAIL: materialized view <schemaname>.<viewname> depends on function
Interesting, did you edit the error log to omit <schemaname> and
<viewname> or is that hiding coming from PostgreSQL itself ?
This would be worth a ticket to think about ways to handle it, but the
message is pretty clear: PostGIS deprecated a function:
st_distance(geography, geography)
But your database is using it in the definition of a materialized view
(which one is hidden).
We do have code in place to handle deprecations but this specific
function is missing the encantation to be handled properly. Filing
a ticket to https://trac.osgeo.org/postgis will help.
--strk;
