[postgis-users] Problem with UpdateGeometrySRID
Marco Boeringa
marco at boeringa.demon.nl
Sun May 28 06:56:38 PDT 2023
I am running into a weird issue I haven't encountered before with
UpdateGeometrySRID.
I have a table that correctly shows up in the 'geometry_columns' view
with the following data:
* f_table_schema=osm
* f_table_name=tmpDissolve0
* f_geometry_column=way
* coord_dimension=2
* srid=4326
* type=GEOMETRY
However, if I look in DBeaver in the table column view, it only shows:
'way(geometry)'
as column type, not:
'way(geometry(geometry(4326))'
as expected and seen on other tables in DBeaver's column view.
I have tried to fix this by running:
SELECT UpdateGeometrySRID('osm','tmpDissolve0','way',4326);
from within a larger Python script, but this unexpectedly errors out with:
"column not found in geometry_columns table
CONTEXT: PL/pgSQL function updategeometrysrid(character
varying,character varying,character varying,character varying,integer)
line 35 at RAISE
SQL statement "SELECT public.UpdateGeometrySRID('',$1,$2,$3,$4)"
PL/pgSQL function updategeometrysrid(character varying,character
varying,character varying,integer) line 5 at SQL statement"
When I tried the "alternative", as mentioned on the Help page of
UpdateGeometrySRID (https://postgis.net/docs/UpdateGeometrySRID.html),
which according to the Help text should be equivalent:
ALTER TABLE osm.tmpDissolve0 ALTER COLUMN way TYPE
geometry(GEOMETRY,4326) USING ST_SetSRID(way,4326);
this succeeds, and I see correctly:
in DBeaver.
My main question: why does UpdateGeometrySRID fail here, while the
equivalent code succeeds?
Version information:
Postgres version: 15.3 (Ubuntu 15.3-1.pgdg22.04+1)
PostGIS version: POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150"
GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1" LIBXML="2.9.13" LIBJSON="0.15"
LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
Marco
