[postgis-users] Failing ST_Transform with Ross Ice Shelf polygon
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 6 15:39:37 PST 2023
> On Nov 6, 2023, at 3:33 PM, Marco Boeringa <marco at boeringa.demon.nl> wrote:
> Well, yes indeed that is what is happening, 180 came out of the reprojection steps as -180. Full output geometry below. Is there any way to prevent this behavior?
> Marco
Not really… Either snap to grid or reduce precision
https://postgis.net/docs/ST_ReducePrecision.html
https://postgis.net/docs/ST_SnapToGrid.html
will get you back onto the dividing line (note that it is at -180.00000000000014), but that won’t help in flipping -180 to 180. For your particular case, applying
https://postgis.net/docs/ST_ShiftLongitude.html
will fix it, I think, though not in generality
P
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231106/12593593/attachment.htm>
