[postgis-users] Topology - RemoveUnusedPrimitives workflow
Sandro Santilli
strk at kbt.io
Wed Nov 8 02:14:24 PST 2023
On Wed, Nov 08, 2023 at 10:05:39AM +0000, Alexandre Neto wrote:
> Thanks Sandro, I will. And I will try to PR on the documentation.
> One extra question. When I add a topoGeometry column to a table with a geometry column, in QGIS, I now fail to be able to edit the table. It seems that the PostGIS provider forces me to use a key called tid. Nevertheless, I can't find this column anywhere in the table. The workaround is to load the layer in QGIS before adding the TopoGeometry column, which is cumbersome. Is this intended or could it be a bug?
Sounds like a bug to me. When you file it make sure to specify which
layer load method you use as I'm pretty sure the browser and the
postgresql-specific panel behave differently.
--strk;
