[postgis-users] PGAdmin4 - not getting swamped by geometry columns in data view?
Nicolas Ribot nicky666 at gmail.com
Wed Oct 18 01:42:26 PDT 2023
Hello,
You can choose the default columns size in PgAdmin preferences. It defaults
to "column data" but you can set it to be "column name":
"If set to 'Column data' columns will auto-size to the maximum width of the
data in the column as loaded in the first batch. If set to 'Column name',
the column will be sized to the widest of the data type or column name"
Go to preferences -> Query Tool -> Result Grid -> Columns sized by...
Nicolas
On Wed, 18 Oct 2023 at 07:57, Gary Turner via postgis-users <
postgis-users at lists.osgeo.org> wrote:
> Apologies in advance if this is a silly question, or this is an
> inappropriate place to ask.
> I've recently switched from pgadmin3 to 4 on a new windows machine, and
> I occasionally use it to look at metadata. The tables I use
> unfortunately tend to have the geometry columns at the left of the table.
> In V3, the geometry was width limited. In 4 it's not, and I can't even
> scroll past the geometry column to find the data that's to the right of it.
> Is there a way to limit the width of the geometry column? Or even hide it?
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20231018/6407aec1/attachment.htm>
