[postgis-users] JSONC compilation issues (Regina Obe)
Regina Obe lr at pcorp.us
Thu Sep 21 18:48:22 PDT 2023
I use environment variables too, I’m just saying stuff it in a PKG_CONFIG_PATH environment variable instead.  That is the more modern way of doing things and things like PROJ (the proj-dir is deprecated) not even sure it works anymore.  So I stuff PROJ in my PKG_CONFIG_PATH environment variable as I do SQLite etc.
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of Light via postgis-users
Sent: Thursday, September 21, 2023 7:18 PM
To: postgis-users at lists.osgeo.org
Cc: Light <wangdapeng20191008 at gmail.com>
Subject: Re: [postgis-users] JSONC compilation issues (Regina Obe)
Regina,
Environment variables are a great way to build things.
I used json-c version=0.13 in the past, using --with-jsondir and had no compilation failures.
But after I upgraded to json-c=0.15, the folder changed and became lib64.
I tried to compile json-c-0.13, 0.14, and 0.15, and found that only 0.13 is lib, and the others are lib64.
Summary, json-c-0.14>=lib64.
Thanks,
Wang Dapeng
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20230921/faa8b68d/attachment.htm>
