ST_Slope query is slow.
Dapeng Wang
wangdapeng20191008 at gmail.com
Mon Apr 8 23:42:04 PDT 2024
Hello,
-The computation of slope (in degrees) is relatively slow, taking about 20
seconds for analysis using ArcGIS Pro.
version:pg12+postgis340
--postgis_full_version
POSTGIS="3.4.0 0" [EXTENSION] PGSQL="120" GEOS="3.12.0-CAPI-1.18.0"
SFCGAL="SFCGAL 1.4.1, CGAL 5.4.5, BOOST 1.72.0" PRO
J="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/postgres/.local/share/proj
DATABASE_PATH=/usr/local/proj-8.2.1/share/proj/proj.db" GDAL="GDAL 3.6.2,
released 2023/01/02" LIBXML="2.9.11" LIBJSON="
0.15" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
raster2pgsql -I -s 4326 -t 32x32 "/opt/raster_data/changjiang12.tif" | psql
-h localhost -p5432 -Upostgres -dpostgis340
-After importing, the TIFF file is 14MB and 12198 rows.
postgis340=# \d changjiang12
Table "public.changjiang12"
Column | Type | Collation | Nullable | Default
rid | integer | | not null |
nextval('changjiang12_rid_seq'::regclass)
rast | raster | | |
Indexes:
"changjiang12_pkey" PRIMARY KEY, btree (rid)
"changjiang12_st_convexhull_idx" gist (st_convexhull(rast))
postgis340=# EXPLAIN ANALYSE select ST_Slope(rast) as slope from
changjiang12;
QUERY PLAN
Seq Scan on changjiang12 (cost=0.00..4894.48 rows=12198 width=32) (actual
time=22.371..142759.655 rows=12198 loops=1)
Planning Time: 0.836 ms
Execution Time: 142764.987 ms
(3 rows)
Time: 142770.199 ms (02:22.770)
-Where can improvements be made?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240409/c710debd/attachment.htm>
