Segmentation fault restoring data to Azure VM
Marco Boeringa marco at boeringa.demon.nl
Tue Apr 23 10:58:43 PDT 2024
Jeffrey,
As the output shows, you did not yet upgrade the PostGIS core procedures
on your source data physical server, so it doesn't yet run with the full
upgrade to the latest PostGIS.
Run "SELECT postgis_extensions_upgrade()" against your source database.
Marco
Op 23-4-2024 om 19:20 schreef Jeffrey Durrence:
> Regina,
> Thank you so much for your quick response (and for your contributions
> to the rest of us in your writings)!
> On the physical server I have:
>  POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="150"
> GEOS="3.10.2-CAPI-1.16.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
> DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.4.3, released
> 2022/04/22" LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
> WAGYU="0.5.0 (Internal)" (core procs from "3.4.1 ca035b9" need
> upgrade) RASTER (raster procs from "3.4.1 ca035b9" need upgrade)
> On the Azure server I have
> GEOS="3.11.1-CAPI-1.17.1" (compiled against GEOS 3.10.2) PROJ="8.2.1
> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> WAGYU="0.5.0 (Internal)" RASTER
> There are some differences, though I'm not sure of the best strategy
> to reconcile this.  As for the raster extension, I don't use it for my
> workflows.  I could drop the postgis_raster extension and see if that
> allows my export/import to succeed without error.
> -Jeffrey
> Jeffrey Durrence
> McLean Engineering Company
> www.mcleanengineering.com <http://www.mcleanengineering.com/>
> Office: 229-985-1148
> Mobile: 229-798-0480
> *From:* Regina Obe <lr at pcorp.us>
> *Sent:* Tuesday, April 23, 2024 1:09 PM
> *To:* Jeffrey Durrence <jeffrey.durrence at mcleanengineering.com>;
> postgis-users at lists.osgeo.org <postgis-users at lists.osgeo.org>
> *Subject:* RE: Segmentation fault restoring data to Azure VM
> What does
> SELECT postgis_full_version();
> Run on your current setup vs. your Azure VM setup.
> Might thinking is it might be a dependent library crashing.
> Usually the issues are with postgis_raster extension since that drags
> in GDAL which drags in several more libraries.
> Could also be an issue with PROJ.  As I recall at least on windows, I
> used to get crashes if PROJ_LIB path wasn’t set, but I think that
> issue has gone away with recent releases.
> Not sure if it was ever an issue on Linux or Unix.
> Hope that helps,
> Regina
> *From:*Jeffrey Durrence <jeffrey.durrence at mcleanengineering.com>
> *Sent:* Tuesday, April 23, 2024 11:42 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Segmentation fault restoring data to Azure VM
> Greetings,
> I am migrating PostgreSQL/PostGIS databases from a physical server
> with these specs:
> Host OS: Ubuntu 22.04.4 LTS x64 (32GB RAM, 8GB Swap, 1TB disk space,
> XEON E5-1660 CPU)
> Postgres: 15.6.1-pgdg22.04+1
> PostGIS: 3.4.2
> To an Azure VM with
> Host OS: Ubuntu 22.04.4 LTS x64 (32GB RAM, 8GB Swap, 512GB disk space,
> XEON 8171M) (again, this is in Azure VM)
> PostGIS: 3.4.2
> In the past, I have migrated the same data from on the same physical
> hardware for changes in host O/S, Postgres version, and/or PostGIS
> version. I've also migrated from one physical host to another.  When
> doing so, I try to make sure that my software packages are up to date
> and that the packages in the destination environment match.  I did
> this for this planned environment as well.  Because I know that some
> of my dbs have several years of history in them, I export these dbs
> individually using pg_dump (using the custom format when possible but
> in some cases I use the plain text option) and pg_restore on the
> destination host.
> During the process of migrating data in this manner, I observed that
> restoration of many of my dbs failed.  I did lots of testing with this
> and have made these additional observations:
>  1. I am able to restore my export files to another physical host with
>     the same software environment without error.  (the errors occur
>     when importing to virtual environment).
>  2. If I split my export/import into separate steps for the schema and
>     data, it is the schema import that produces the error, not the
>     data import.
>  3. When the error occurs, the db process terminates with a
>     segmentation vault (see log output below), and the db process
>     restarts.
>  4. With logging of all statements enabled, I can see that the
>     segmentation vault occurs at the absolute end of the import, when
>     it seems that all commands are completed.  So long as I wait on
>     the server process to recover, I have no errors when I import the
>     data following the error.
>  5. The db imports that produce these errors seem to be those with
>     more history (e.g., it's more likely that these were created with
>     an older version of postGIS and subsequently upgraded to the
>     versions they have now).
>  6. The errors do seem related to the installation of the PostGIS
>     extension.  If I purposely drop the extension from the source
>     database before I export, the resulting file can be imported in
>     the target environment without error.  This is obviously
>     undesirable as it results in my losing all of the geometry info
>     from tables, views, etc. in the db.  I only did this to experiment.
> My typical restore command looks like this:
> pg_restore --verbose --format=custom --dbname=my_db
> /tmp/my_db_schema_only.backup
> (plus some options to capture the output)
> Here's a look at what the command line output looks like when this
> happens:
> LOG:  server process (PID 52476) was terminated by signal 11:
> Segmentation fault
> LOG:  terminating any other active server processes
> LOG:  all server processes terminated; reinitializing
> LOG:  database system was interrupted; last known up at 2024-04-23
> 02:16:49 UTC
> LOG:  database system was not properly shut down; automatic recovery
> in progress
> LOG:  redo starts at 5/51381960
> WARNING:  could not open directory "base/696372": No such file or
> directory
> CONTEXT:  WAL redo at 5/51381A48 for Database/DROP: dir 1663/696372
> WARNING:  some useless files may be left behind in old database
> LOG:  invalid record length at 5/52679558: expected at least 24, got 0
> LOG:  redo done at 5/526794E0 system usage: CPU: user: 0.07 s, system:
> 0.01 s, elapsed: 0.10 s
> LOG:  checkpoint starting: end-of-recovery immediate wait
> LOG:  checkpoint complete: wrote 2699 buffers (16.5%); 0 WAL file(s)
> added, 1 removed, 0 recycled;
> B; lsn=5/52679558, redo lsn=5/52679558
> LOG:  database system is ready to accept connections
> In the log file, the section written as the error occurs is something
> like this...
> [60419] [6627bcbb.ec03] [2024-04-23 13:50:54.813 UTC] [0]: LOG:
>  statement: GRANT ALL ON TABLE my_schema.my_table TO my_user_name;
> [60419] [6627bcbb.ec03] [2024-04-23 13:50:54.815 UTC] [0]: LOG:
>  statement: -- Completed on 2024-04-23 13:50:54 UTC
>  statement: --
> -- PostgreSQL database dump complete
> [59940] [6627b39f.ea24] [2024-04-23 13:50:54.943 UTC] [0]: LOG:
>  server process (PID 60419) was terminated by signal 11: Segmentation
> fault
> [59940] [6627b39f.ea24] [2024-04-23 13:50:54.945 UTC] [0]: LOG:  all
> [60423] [6627bcbf.ec07] [2024-04-23 13:50:55.007 UTC] [0]: LOG:
>  database system was interrupted; last known up at 2024-04-23 13:50:48 UTC
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:05.511 UTC] [0]: LOG:
>  syncing data directory (fsync), elapsed time: 10.00 s, current path:
> ./base/897556/1249
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.554 UTC] [0]: LOG:
>  database system was not properly shut down; automatic recovery in
> progress
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.606 UTC] [0]: LOG:  redo
> starts at E/3A8785A8
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.607 UTC] [0]: WARNING:
>  could not open directory "base/562219": No such file or directory
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.607 UTC] [0]: CONTEXT:
>  WAL redo at E/3A878690 for Database/DROP: dir 1663/562219
>  some useless files may be left behind in old database directory
> "base/562219"
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.704 UTC] [0]: LOG:
>  invalid record length at E/3BACDAF8: expected at least 24, got 0
> [60423] [6627bcbf.ec07] [2024-04-23 13:51:12.704 UTC] [0]: LOG:  redo
> done at E/3BACDA80 system usage: CPU: user: 0.07 s, system: 0.01 s,
> elapsed: 0.09 s
> [60424] [6627bcbf.ec08] [2024-04-23 13:51:12.804 UTC] [0]: LOG:
> [60424] [6627bcbf.ec08] [2024-04-23 13:51:13.143 UTC] [0]: LOG:
>  checkpoint complete: wrote 2592 buffers (15.8%); 0 WAL file(s) added,
> 1 removed, 0 recycled; writ
> 9 s, average=0.001 s; distance=18773 kB, estimate=18773 kB;
> lsn=E/3BACDAF8, redo lsn=E/3BACDAF8
> [59940] [6627b39f.ea24] [2024-04-23 13:51:13.156 UTC] [0]: LOG:
> I searched the mail archive and performed some additional web searches
> based on my observations. Unfortunately, I haven't found a
> similar-enough incident where I might get suggestions for further
> troubleshooting.  In over 10 years of using PostgreSQL+PostGIS, I've
> never had to dig this deeply to determine the source of error.  I'm
> looking for advice for further troubleshooting or for shared
> experiences in similar situations
> Thank you for your time!
> Jeffrey Durrence
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240423/9d24bb60/attachment.htm>
