Proj4text is still working
José Carlos Martínez jomarlla at upv.es
Wed Apr 24 06:46:35 PDT 2024
Hi list
I am making some changes in proj4text of the spatial_ref_sys table, to
apply a transformation between datums (+towgs84).
It appears that PostGIS is not using the values from proj4text, and
instead is using the values from proj.db in the proj directory.
I would like to ask if proj4text values still take priority (as in
previous versions), with respect to proj.db?
I mean, the first place PostGIS looks at the values to perform a
coordinate transformation is still proj4text?
Thanks
Jose Martinez
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240424/1055e60e/attachment.htm>
