Proj4text is still working
José Carlos Martínez jomarlla at upv.es
Fri Apr 26 02:01:45 PDT 2024
Hi Paul
Thanks for your answer.
With a new entry in spatial_ref_sys is working but some comments:
In previous versions of PostGIS (I do not remember from which one)  I
just used proj4text to change the 7 helmert transform values (towgs84)
between datums.
With a new entry in spatial_ref_sys:
- Now (PostGIS 3.4), proj4text is not working, in fact I can put an
empty text in proj4text and st_transform gives me the same results
(after restarting the server for avoiding cache effects of proj4/postgis).
- To custom the towgs84 values, I need to change the towgs84 values in
SRTEXT..this way its working!
It is PostGIS/Proj4 using srtext insted of proj4text? from which version?
Thanks again
Jose Martinez
El 24/04/2024 a las 16:11, Paul Ramsey escribió:
> On Wed, Apr 24, 2024 at 6:46 AM José Carlos Martínez via postgis-users
> <postgis-users at lists.osgeo.org> wrote:
>> I am making some changes in proj4text of the spatial_ref_sys table, to apply a transformation between datums (+towgs84).
> Don't make changes to existing, defined entries, make yourself a new entry.
>> It appears that PostGIS is not using the values from proj4text, and instead is using the values from proj.db in the proj directory.
> Yes, if it can dereference an SRID to an entry in proj.db, that entry
> will be what is used. This allows richer and more correct transforms
> than can be achieved with the proj string entries alone.
>> I would like to ask if proj4text values still take priority (as in previous versions), with respect to proj.db?
>> I mean, the first place PostGIS looks at the values to perform a coordinate transformation is still proj4text?
> No, the first place is the proj.db. This is why if you want a custom
> system you should make a new entry.
> ATB,
> P
>> Thanks
>> Jose Martinez
José Carlos Martínez Llario
http://www.upv.es/ficha-personal/jomarlla
https://cartosig.webs.upv.es
Producción Cartográfica y SIG.
Dpto. Ingeniería Cartográfica.
Univ. Politécnica de Valencia.
