Update postgis in a replicated PostgreSQL 12 database now with postgis-3
Sandro Santilli
strk at kbt.io
Wed Aug 7 10:07:37 PDT 2024
On Mon, Jul 01, 2024 at 04:37:37PM +0100, Andrew Hardy wrote:
> Thank you so much for your response, I appreciate it.
> I omitted to mention that before I messaged I had tried to resolve this in
> the pg_proc table and ran the following query:
> UPDATE pg_proc SET probin = '$libdir/postgis-3' WHERE probin =
> '$libdir/rtpostgis-2.5';
> This was probably a mistake (not least that postgis-3 is not the raster
> library) and I am wondering if this is resolvable.
Yes, it was a mistake.
Running this should fix it:
SELECT postgis_extensions_upgrade();
> Q1: And I am wondering if the postgis_extensions_upgrade() mentioned in
> the upgrade instructions assumes one is starting from a particular state
> and I need to get back there from my mistake above or if this upgrade
> function will resolve things whatever the state.
It tries its best to resolve things whatever the state, but I guess it
could fail, you'll tell us.
> Q2: Should I still run postgis_full_version() - is this function a
> benign query, unlike postgis_extensions_upgrade() ?
Always run `postgis_full_version()` to tell what the state of the
database is.
--strk;
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240807/314281ce/attachment.sig>
