Getting FIR from map
Alexandre Neto
senhor.neto at gmail.com
Fri Dec 13 12:41:23 PST 2024
Unless your PDF is a geoPDF, you won't be able to retrieve any geometries
from it.
Try to drag and drop it into QGIS, if it loads, then you can use the import
to PostgreSQL (new connection) to send the layer to the database.
A sexta, 13/12/2024, 17:25, Luca Bertoncello <lucabert at lucabert.de>
escreveu:
> Dear all,
> Surely a little Off Topic, but I don't know where other I can ask...
> I need to import the FIR into my database.
> For me it is very important to get the region with their codes.
> As region I intend these:
> https://www.eurocontrol.int/sites/default/files/2024-05/eurocontrol-firuir-lower-airspace-europe-2024.pdf
> My problem is to convert the regions of the PDF in coordinate series to
> import in my database.
> I really don't have any idea how to do that.
> Surely there are tools to do that, but I don't know them...
> Can someone suggest me how to solve my problem, if possibile in an
> automated way, so that if the map changes I can reimport the data?
> Thank you very very much!
> Luca Bertoncello
> (lucabert at lucabert.de)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241213/4a7726c5/attachment.htm>
