Options to rollback PostGIS upgrade
Regina Obe lr at pcorp.us
Mon Feb 26 06:53:26 PST 2024
Which version of PostGIS are you coming from again?
In theory, as long as your old is running a newish PostGIS 3+, it should be safe enough to just NOT run
SELECT postgis_extensions_upgrade();
If you don’t run that, then your database is just running with a newer lib file, but old scripts.  So then just installing the binaries of older should work fine.
One caveat, I believe we did make sure changes that caused some functions not to work, but I can’t remember what those were.
All I know is if you run
SELECT postgis_full_version();
And you get an error after upgrading your binaries, then not running postgis_extensions_ugprade is not an option.
Sent: Monday, February 26, 2024 3:30 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Options to rollback PostGIS upgrade
Hi Team,
We are looking at options available to rollback a PostGIS upgrade in case there are issues after the upgrade.
Apart from removing new packages and installing old ones and then restoring the database from backup , do we have any other option?
Thanks,
Nikhil
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240226/ee5fd6f2/attachment.htm>
