Postgres segfaults on raster query
Regina Obe
lr at pcorp.us
Thu Jan 18 20:16:18 PST 2024
> Here's what's happening:
> psql -d mydb
> select rid from rastertable where rid = 1;
> Psql connection drops, postgres segfaults and restarts.
> BUT, if I do a query such as this FIRST:
> select postgis_full_version();
> Then do other raster queries, it works fine. I suspect I broke something but I'm
> not sure where to start.
> Thanks for any help.
> Scott
What other extensions do you have loaded.
Also what does your output return for
SELECT postgis_full_version();
Only thing I can think of is calling postgis_full_version() is causing the raster and postgis extensions to preload,
I'd check to see if you have anything in
SHOW shared_preload_libraries;
You might actually want to try doing something like:
ALTER SYSTEM SET shared_preload_libraries = 'postgis-3';
And then restart your service to see if it has the same effect as the SELECT postgis_full_version();
