Detailed st_mapalgebra reference?
Regina Obe lr at pcorp.us
Tue Jul 30 11:28:17 PDT 2024
For basic boolean logic, I would highly suggest just using Reclass, as it’s much faster
https://postgis.net/docs/RT_ST_Reclass.html
Generally speaking I think any algebraic operations and I recall even CASE statements allowed in SQL are allowed though I haven’t fully tested that.
If you are doing more complex things than that, you probably should just create a mapalgebra callback function to use.
There are some already part of PostGIS proper that are mostly written in plpgsql so you can peak and see how they work
https://postgis.net/docs/RT_reference.html#Raster_Processing_MapAlgebra_Callbacks
and then stuff into - https://postgis.net/docs/RT_ST_MapAlgebra.html
Sent: Tuesday, July 30, 2024 2:09 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Detailed st_mapalgebra reference?
We are doing a ton of precip raster analysis and rectification, and we are struggling to find details on the algebraic expressions that we can use, ie, "[rast1] + [rast2]" is great if we are adding, but we are also interested in boolean calculations etc.
The basic postgis reference page is great for understanding syntax but I am looking for recipes or a large raster calculator reference.
Thanks on advance,
Robert
Robert W. Burgholzer
 'Making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity.'  - Charles Mingus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240730/2d0cffe2/attachment.htm>
