ERROR : function st_astext(postgis.geometry) doesn't exist
Regina Obe lr at pcorp.us
Fri Jun 21 06:59:20 PDT 2024
Usually the reasons I get that error are
1.	You did not reconnect after setting search_path of the database. The search path if set at the db level, does not take effect until after reconnection.
2.	You did not give permissions to those functions or usage to the schema.
From: Bharath Tadikonda <tadikondabharath at gmail.com>
Sent: Friday, June 21, 2024 9:06 AM
To: postgis-users at lists.osgeo.org
Subject: ERROR : function st_astext(postgis.geometry) doesn't exist
Hello team,
A database user has encountered an ERROR : function st_astext(postgis.geometry) doesn't exist while trying to query st_astext(bbox) function
database search path is already set with 'postgis' but still sees the error.
Can you please advise what is the issue here?
Regards,
Bharath
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240621/e964e8f0/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240621/e964e8f0/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240621/e964e8f0/attachment-0001.png>
