Running clustering queries
Regina Obe
lr at pcorp.us
Wed Mar 27 16:14:03 PDT 2024
That's the function I would have suggested.
What query are you trying to run and what is the spatial reference system id
for your data.
I'm guessing the issue might be your units of measure. If you want to do
500 ft you'd be best using a meter or mile based spatial reference system.
> -----Original Message-----
> From: Max Pyziur <pyz at brama.com>
> Sent: Wednesday, March 27, 2024 5:33 PM
> To: postgis-users at lists.osgeo.org
> Subject: Running clustering queries
> Greetings,
> I have a dataset of filling stations with point geometries (about 80k U.S.
filling
> stations)
> I'm trying to find/make clusters of this data (with a criteria like say
minimum
> of 3 stations w/in 500 feet of each other.
> I've found these webpages; but as yet I can't produce any sort of
meaningful
> results.
> I would appreciate any and all guidence. Thank you.
> Max Pyziur
> pyz at brama.com
> Webpages:
> Examples Of Spatial Clustering With PostGIS - February 28, 2024
> https://mapscaping.com/examples-of-spatial-clustering-with-postgis/
> ST_ClusterDBSCAN
> https://postgis.net/docs/ST_ClusterDBSCAN.html
> PostGIS Clustering with DBSCAN | Crunchy Data Blog
> https://www.crunchydata.com/blog/postgis-clustering-with-dbscan
> clustering - PostGIS nest ST_ClusterKMeans on results of ST_ClusterKMeans
> - Geographic Information Systems Stack Exchange
> https://gis.stackexchange.com/questions/396029/postgis-nest-st-
> clusterkmeans-on-results-of-st-clusterkmeans
