linear reference/dynamic segmentation
Regina Obe
lr at pcorp.us
Wed May 8 07:56:04 PDT 2024
Not sure what you mean by dynamic attributes.
If you need something to position points along a line, so that you can put
an info tip on each point, they youll want to use
https://postgis.net/docs/en/ST_LineInterpolatePoints.html
Something like below will give you a point every 20 percent along the
linestring
SELECT dp.geom
>From your_table, ST_DumpPoints(ST_LineInterpolatePoints(your_table.geom,
0.2, true)) AS dp
From: SERGIO ACOSTAYLARA <sergio.acostaylara at mtop.gub.uy>
Sent: Wednesday, May 8, 2024 9:21 AM
To: postgis-users at lists.osgeo.org
Subject: linear reference/dynamic segmentation
Hi. Is there anybody in the list that has any experience using linear
reference/dynamic segmentation with postgis? We need to show dynamic
attributes in our geoportal/visualizer. Is this possible to do it with
postgis?
Thanks in advance
Sergio Acosta y Lara
Departamento de Geomática
Dirección Nacional de Topografía
Ministerio de Transporte y Obras Públicas
URUGUAY
(598)29157933 ints. 20329
http://geoportal.mtop.gub.uy/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240508/0fe6928b/attachment.htm>
