Using ST_AsRaster function got a abnormal result
tlgeo george
georgetlgeo at gmail.com
Mon May 20 19:34:00 PDT 2024
Hello folks,
When I use ST_AsRaster in Postgis, I can't get the expected result.
My SQL: SELECT ST_AsPNG(ST_AsRaster(ST_GeomFromText('POLYGON((4 3,4 2,1 2,1
3,4 3))'),150, 150,ARRAY['8BUI'],ARRAY[4],ARRAY[0])) ;
I write the select result into byte[] and write into disk tiff file in Java.
But I got a file like this:
[image: image.png]
This result file is in the attached file.
I think the right result should contain nodata district ,but my result file
did't.
Any clues will appreciate,thank you very much.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240521/2644a7d9/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240521/2644a7d9/attachment.png>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240521/2644a7d9/attachment.tiff>
