upgrade pg from 11 to 16 and postgis
Regina Obe
lr at pcorp.us
Thu May 30 08:58:15 PDT 2024
I think the GDAL library is part of the pgdg-common lib. I know in Centos 7
I used to manually add these to my yum repo list, but I thought for 8 and on
this was automatically done.
https://yum.postgresql.org/news/rocky-9-8-llvm-repo-is-available/
Sent: Thursday, May 30, 2024 4:18 AM
To: Regina Obe <lr at pcorp.us>; postgis-users at lists.osgeo.org
Subject: Ynt: upgrade pg from 11 to 16 and postgis
Thank you <mailto:lr at pcorp.us> @Regina Obe for your reply.
Even if I try install latest postgis version, getting the same dependency
errors
Full version the os after installation
_____
Gönderen: Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> >
Gönderildi: 29 Mayıs 2024 Çarşamba 16:59
Kime: 'Bekir Niyaz' <bagafoot at hotmail.com <mailto:bagafoot at hotmail.com> >;
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
<postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Konu: RE: upgrade pg from 11 to 16 and postgis
I think there is probably only one version of PostGIS 3 series that is
shipped with each major version of PostgreSQL on yum, which is fine.
Just go with 3.4. The file names for 3 series regardless the minor doesn't
change and is always postgis-3.so and postgis_raster-3.so
As far as trying to install PostGIS 2.5, DO NOT, just use the symlink
approach to fix as discussed here:
<https://www.bostongis.com/blog/index.php?/archives/278-Using-pg_upgrade-to-
upgrade-PostgreSQL-9.6-PostGIS-2.4-to-PostgreSQL-15-3.3-on-Yum.html>
https://www.bostongis.com/blog/index.php?/archives/278-Using-pg_upgrade-to-u
Hope that helps,
Regina
From: Bekir Niyaz <bagafoot at hotmail.com <mailto:bagafoot at hotmail.com> >
Sent: Wednesday, May 29, 2024 8:58 AM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: upgrade pg from 11 to 16 and postgis
Hello,
Im trying to update pg11 to pg16 (and postgis from 2.5 to 3.3) but my server
oracle linux 7 which doesnt support pg16.
Then I upgraded ora linux to 8, but now pg repos doesnt support pg11.
Then I installed archive repo (pgdg11-archive) to install pg11 binaries. It
is working well but upgrade os deleted all pg11 and related binaries
including postgis2.5
Now when I running pg_upgrade --check it says me there no postgis2.5
packages.
In database: test
could not load library "$libdir/postgis-2.5": ERROR: could not access file
"$libdir/postgis-2.5": No such file or directory
When I trying to install postgis getting
Enabled repo list
Q1 : how to solve dependency error, even there enabled epel repo?
Q2: why in below list doesnt exist postgis33_16.x86_64 packages ?
Best regards.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20240530/7104b2cc/attachment-0004.png>
