Advice on loading OpenTopography data into a PostGIS database apreciated
thiemo at gelassene-pferde.biz thiemo at gelassene-pferde.biz
Fri Nov 1 16:39:36 PDT 2024
I totally forgot to mention that my PostgreSQL database runs on Debian
Bookworm and is version 17. The database binaries and PostGIS are
installed by the PostgreSQL repository.
treintaytres=> SELECT postgis_full_version();
  POSTGIS="3.5.0 d2c3ca4" [EXTENSION] PGSQL="170"
GEOS="3.11.1-CAPI-1.17.1" PROJ="9.1.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.11.1)
GDAL="GDAL 3.6.2, released 2023/01/02" LIBXML="2.9.14" LIBJSON="0.16"
LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" RASTER
(1 row)
treintaytres=> SELECT version();
                                                        version
  PostgreSQL 17.0 (Debian 17.0-1.pgdg120+1) on x86_64-pc-linux-gnu,
compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
(1 row)
