Creating spatial indexes on geography slower than on geometry?
Marco Boeringa
marco at boeringa.demon.nl
Sat Nov 2 02:19:50 PDT 2024
Paul,
Just wondering, given the fact that, as it now turns out, the specific
step to calculate the bounding boxes is such a large part of the overall
time of the building of the GiST spatial index, shouldn't this
particular step be parallelized in PostgreSQL via parallel workers?
I realize that with that question, this has become more of a question
for the PostgreSQL mailing list, but you likely have some idea if that
is even viable given your detailed knowledge of what goes on with GiST
spatial indexing.
However, with apparently 90% or so of all of the building time of the
GiST spatial index for Polygon geometries being determined by this
particular step, and no indications of use parallel processing taking
place (low IO, only one core at 100% from what I usually see), that
question seems warranted.
Parallelizing this step would likely also benefit 'geometry' storage
spatial indexing as well. Even though it is faster than 'geography', it
is still a major process taking many hours for Planet data.
It might be a nice GSOC project to explore if this step could be
parallelized.
Marco
Op 1-11-2024 om 16:28 schreef Paul Ramsey:
> Basically, yes. Calculating a bbox on a plane is just some min/max
> calls. Doing it on a sphere involves a lot of trig and huge functions.
> Calculating boxes is step one of index building. The geocentric
> geography index involves a varsize key, while the 2d geometry index
> uses a fixed size key. Even things like distance cost a lot more
> https://docs.google.com/presentation/d/1G7UkT9szpyRcWPp59aVRfN1-f1jfuf40dwxs034M2RA/edit#slide=id.g4c694067b3_0_79
> p
>> On Nov 1, 2024, at 8:13 AM, thiemo at gelassene-pferde.biz wrote:
>> Is that because geometry is calculated in the plane whereas geography
>> on a curved surface?
>> Paul Ramsey <pramsey at cleverelephant.ca> escribió:
>>> Yes, building a geography index is a lot more computationally expensive.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241102/ce1fb3d9/attachment.htm>
