Composing raster tiles?
Regina Obe lr at pcorp.us
Fri Nov 8 22:11:53 PST 2024
The main overhead I see with postgis raster are the following
1.	Limitation of raster sizes of about 1GB as I recall
2.	Detoasting of data which is almost always needed  https://www.postgresql.org/docs/current/storage-toast.html
3.	Mem copying of data, probably more so than using say GDAL directly
4.	Probably easier to do parallel operations on command line (though admittedly I haven’t tried)
Admittedly my experience with using GDAL and python directly is very low compared to doing everything in the database so I really don’t know the benefits of doing it all in GDAL.
I still prefer to use the database hammer over having to learn yet another tool.  My sense is also that the amount of SQL/plpgsql code you have to write would be much less than trying to pull your stuff out of the DB and stuff it in python/GDAL to do the same thing.  This is all to say if the performance is good enough for you, I say go for that hammer even if you think you are just dealing with a nail.
From: Thiemo Kellner <thiemo at gelassene-pferde.biz>
Sent: Friday, November 8, 2024 12:16 PM
To: PostGIS Users <postgis-users at lists.osgeo.org>
Subject: Re: Composing raster tiles?
Thanks for sharing your experience. Is that saying that PostGIS has considerable overhead? Sorry, if that is naiv. I might be suffering from the hammer nail deficiency. My background is very database heavy, so too much might look like a database to me.
08.11.2024 16:15:32 Vera Green <vera.green.ca at gmail.com <mailto:vera.green.ca at gmail.com> >:
We use command line GDAL for all our Easter processes, if your data is large I recommend you look into that option.
On Fri, Nov 8, 2024, 6:12 AM David Haynes <haynesd2 at gmail.com <mailto:haynesd2 at gmail.com> > wrote:
I'll try and help you with A & B
a) Is it more efficient to convert the raster to vector data and calculate on the those than to calculate directly on the raster?
>> I don't think it would be faster to convert to vector because that would be dumping the raster into polygons. I think for specifically calculating slope, you are better off staying in raster.
b) To my understanding, if I calculate the slope on a raster tile, the slope,… of the borders will have accuracy problems. My I idea, was to "stitch" a tile with its direct neighbours, calculate on the composed  tile, and either save a cropped calculated composed tile to its  original dimension or save the calculated composed tile as is,  probably the latter.
>> Overall correct, some small adjustments. For any raster operation, the tiles are operated on independently, so you need to "stitch" them together. I've provided a couple of ways in pseduo code
Way 1
1) Use ST_Union and make a big tile,
2) Do the spatial operation,
3) Break it up using ST_Tile()
The downside is you might run out of memory doing this. Also consider ST_MemUnion()
SELECT ST_Tile(ST_Slope(ST_Union(r1.ras)), 350,350)
FROM raster_table
Way 2)
A second option is to basically create an aggregate, which is likely faster.
1) Union the tiles based on ST_Touch  - make mega_tiles
2) Do the spatial operation on the mega_tiles
3) Clip the mega_tiles by the old tiles bounding box
WITH rtest as
SELECT r1.ras, ST_Union (r1.ras) as megatile
FROM raster_table r1
LEFT JOIN raster_table r2
ON ST_Touches (r1.geom, r2.geom)
GROUP BY r1.ras
SELECT ST_CLIP(ST_SLOPE(megatile), ST_Envelop(r1.rast) ) as ras
FROM rtest
Maybe someone wants to make an aggregate for the raster functions?
On Thu, Nov 7, 2024 at 3:31 PM <thiemo at gelassene-pferde.biz <mailto:thiemo at gelassene-pferde.biz> > wrote:
Hi
In my project
https://sourceforge.net/p/treintaytres/code/HEAD/tree/trunk/code_files/data_storage/ I have the
table
TABLE_SCHEMA    TABLE_NAME      DATA_TYPE       TYPE_NAME       COLUMN_NAME
treintaytres    topo_files␟t    1111            uuid            id
treintaytres    topo_files␟t    93              timestamptz     entry_pit
treintaytres    topo_files␟t    1111            uuid            source_id
treintaytres    topo_files␟t    12              text            file_name
treintaytres    topo_files␟t    1111            raster          tile
treintaytres    topo_files␟t    93              timestamptz     file_creation_pit
treintaytres    topo_files␟t    12              text            file_hash
TILE contains topographical height raster data from OpenTopography.
They are from different regions, let's say, some tiles cover
Switzerland, some cover New Zealand. I want to create slope and other
data from the height data and I have some questions I hope you can
answer or point me to answers.
Can I compose as follows?
with RASTER_NEIGHBORS as (         select R1.TILE   as CURRENT_TILE
                                          ,R2.TILE   as NEIGHBOR_TILE
                                          ,R1.ID <http://R1.ID>      as CURRENT_ID
                                      from TOPO_FILES␟T R1
                           left outer join TOPO_FILES␟T R2
                                        on ST_Touches(R1.TILE
                                                     ,R2.TILE)
                                        or ST_Intersects(R1.TILE
                                                        ,R2.TILE)
                                     where TRUE
                                       --and R1.ID <http://R1.ID>  =
'6b8ca53a-bb5f-4c2b-a9c9-94b6a706e9b0'
                                       and TRUE)
    ,NION as (select CURRENT_TILE as TILE
                    ,CURRENT_ID
                from RASTER_NEIGHBORS
              union
              select NEIGHBOR_TILE as TILE
                    ,CURRENT_ID
                from RASTER_NEIGHBORS)
   select ST_Union(TILE) as COMPOSED_TILE
         ,CURRENT_ID
     from NION
group by CURRENT_ID;
c) Finally, I want to select all the areas where slope, TRI,… conform
certain criteria and have a minium surface size. Do I do it this
better on vector data and do I need to do this on data composed of all
the contiguous areas?
I would be grateful for any nudge into the right direction. Maybe URLs
with samples.
Kind regards
Thiemo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241109/e65192d4/attachment.htm>
