The win postgis check
Regina Obe
lr at pcorp.us
Thu Nov 14 10:21:57 PST 2024
Are you building your own postgis and this is during regression testing?
Did you build your own PostgreSQL?
I think I’ve run into that issue before when I was testing against my meson built PostgreSQL. I think it might be those additional // causing the issue.
e.g. has /tmp/pgis_reg/pgis_reg_tmp//test_4_tmp
instead of /tmp/pgis_reg/pgis_reg_tmp/test_4_tmp
I haven’t switched back to my meson build to confirm that is it.
From: Dapeng Wang <wangdapeng20191008 at gmail.com>
Sent: Thursday, November 14, 2024 2:18 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: The win postgis check
Hi everyone,
I encountered two errors while running PostGIS checks on the Windows platform, both related to the COPY command.
+ERROR: could not open file "/tmp/pgis_reg/pgis_reg_tmp//test_4_tmp" for writing: No such file or directory
What should I do?
I have already made sure there are no file permission issues.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241114/3e37f03e/attachment.htm>
