postgis 3.5.0: ST_Within huge performance issue (regression?) with specific geometry (multipolygon)
Paul Ramsey
pramsey at cleverelephant.ca
Fri Nov 22 10:28:18 PST 2024
In order to replicate this I’m going to need both sides of the join. Can you post the ocsge.occupation_sol table as well? Just the geometry column and a unique id is enough. Can you get the postgis_full_version from the server that is “fast”?
Why do you say the index is not being used? Both query plans show what I would expect, which is a nested loop with the small table in a seq scan and the large table (ocsge.occupation_sol) as an index scan.
ATB,
P
> On Nov 22, 2024, at 7:54 AM, Fabien Vallée <fabien.vallee at live.fr> wrote:
> Tested with:
> "POSTGIS=""3.5.0 d2c3ca4"" [EXTENSION] PGSQL=""160"" GEOS=""3.12.1-CAPI-1.18.1"" PROJ=""9.4.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org <https://cdn.proj.org/> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"" LIBXML=""2.9.14"" LIBJSON=""0.17"" LIBPROTOBUF=""1.4.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.4.2 c19ce56"" need upgrade)"
> or another server with same database:
> "POSTGIS=""3.5.0 d2c3ca4"" [EXTENSION] PGSQL=""170"" GEOS=""3.10.2-CAPI-1.16.0"" PROJ=""8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org <https://cdn.proj.org/> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"" (compiled against PROJ 8.10.2) LIBXML=""2.9.13"" LIBJSON=""0.15"" LIBPROTOBUF=""1.3.3"" WAGYU=""0.5.0 (Internal)"""
> Context: departement contains only 101 geometries, but ocsge.occupation_sol is quite big (4860333 entries). BOTH SRID 4326.
> The geometry i'm searching within is a multipolygon (many islands) (and I don't get same behavior searching within something simpler)
> <image.png>
> I'm doing a simple query:
> select a.geometrie from ocsge.occupation_sol
> as a, departement as d
> where ST_Within( a.geometrie, d.geometrie)
> and d.code_insee = '29'
> The request was working fine before (postgis 3.4) as far as I can tell with results within a few seconds max. In that specific case, I am expecting the query
> to return 0 results but now (postgis 3.5) I never get any response, the request justtimeout.
> The query is supposed to use a geometry index (gist):
> <image.png>
> It looks like the index is not used at all (I tried to re-index both tables, no changes). If I an intersects instead, I get results within 3 seconds:
> where ST_Intersects(a.geometrie, d.geometrie)
> (returns 310 results)
> If I do both intersects + within:
> where ST_Intersects(a.geometrie, d.geometrie) and ST_Within(a.geometrie, d.geometrie)
> I get 0 results (as expected) but it's very slow (50 secondes) (query plan attached).
> Testing more, I figured out that _ST_Within is working fine and is much much faster thanST_Within.
> Testing with same geometry (bloody Finistère) against another table (35k rows), ST_Within takes 52 seconds while _ST_Within "only" takes 13 seconds (both with 277 results).
> ST_Intersects takes 5s with 298 results.
> I've also figured out that I don't reproduce the issue testing with searching within another (much simplier) geometry.
> The geometry causing trouble can be downloaded (as geojson, 29MB) here:
> https://send.smart4.io/f.php?h=1G_6egdP&d=1
> (from bdtopo database https://geoservices.ign.fr/bdtopo)
> Please let me know if I'm missing something or if you need anything else to investiguate. Thanks a lot,
> Fabien Vallée
> <query_plan.json>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241122/63f0aacc/attachment.htm>
