postgis 3.5.0: ST_Within huge performance issue (regression?) with specific geometry (multipolygon)
Paul Ramsey pramsey at cleverelephant.ca
Fri Nov 22 18:12:10 PST 2024
Oh, and an easy workaround until release, just use ST_Contains() with the arguments reversed.
P
> On Nov 22, 2024, at 6:10 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Found and fixed for next release
> https://trac.osgeo.org/postgis/ticket/5812
>> On Nov 22, 2024, at 5:43 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> I have duplicated your problem locally, I do not need the test data, thanks!
>>> On Nov 22, 2024, at 3:52 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> Even just a relatively small one should be enough.
>>>> On Nov 22, 2024, at 3:34 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>>>> On Nov 22, 2024, at 3:00 PM, Fabien Vallée <fabien.vallee at live.fr> wrote:
>>>>> Let me know if you find anything, if needed I will provide an extract of the db with enough data to test.
>>>> Please provide a data extract.
>>>> Thanks,
>>>> P
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20241122/83ed0a28/attachment.htm>
