Sphere based calculations for geography don't appear to be faster?
Marco Boeringa
marco at boeringa.demon.nl
Wed Oct 2 04:01:02 PDT 2024
I am not suggesting geographiclib is a bad choice. It may well be the
fastest and most efficient implementation out there for doing geodesic
calculations. It is just that the current PostGIS Help documentation
clearly suggests that switching to sphere based calculations can improve
performance at the obvious cost of some less accuracy. And of course it
would be interesting to know if a true sphere based implementation could
be faster, but maybe nobody bothered to implement one as it can be a
special case of spheroidal, IDK?
It would also be interesting to know if PostGIS uses the 'Geodesic' or
'GeodesicExact' class of geographiclib (or corresponing option on the
'PolygonAreaT' class). It is likely the former as it is well documented
to be faster, but if not due to a possible need to properly support
larger values of flattening, switching to 'Geodesic' or exposing the
option to switch between 'Geodesic' and 'GeodesicExact' in PostGIS,
might be an option. However, I have no idea in what situations using
'GeodesicExact' and larger flattening values is necessary, and if
'GeodesicExact' is a real world use case in common scenario's.
Op 2-10-2024 om 12:37 schreef Greg Troxel:
> Is there data that suggests the geographiclib calculation is taking
> longer than some other code might? There's a lot going on in postgis,
> and without a benchmark showing it's an issue, it feels like it could be
> premature optimization.
